Counting more than 3 shifts in my 03 Auto??
Discussion in 'Technical Chat' started by Taylor, Jan 11, 2013.
  1. Jan 11, 2013 at 6:49 AM
    Taylor
    Taylor [OP] Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Okay, I may sound stupid here, but I thought a 4 speed w/overdrive meant 3 gears, and an overdrive gear as the 4th, right?
    When I drive, I'll count 1-2, 2-3, 3-4... then another shift? My RPMS drop another time.
    Do we have locking torque converters that would cause it to stop slipping and drop my RPMs another ~1000 RPM?
    A friend mentioned something about some auto transmissions having "high and low gears", which, frankly, I'm not buying.
  2. Jan 11, 2013 at 6:57 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    It should be 4 gears plus overdrive making it like a 5 speed. Your shifter should have L,2,3,D that's 4 gears plus overdrive.
  3. Jan 11, 2013 at 6:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    4th is the overdrive. He is experiencing 3shifts, then the torque converter locking up. Many thinks its another gear, which its not.
  4. Jan 11, 2013 at 7:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm not math major but L-2-3-D is only 4 gears :rolleyes:
    OP, what you're probably feeling is the torque convertor locking and thinking it's a shift point. I know the 2nd Gens have a locking torque convertor and you can feel when it locks/unlocks. I'm not if the first gens have that though.
  5. Jan 11, 2013 at 7:06 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    I'm pretty sure your feeling the torque converter locking up as previous posts suggest. I feel it in my 2013 everyday. I also own a f350 powerstroke, and in 3rd when torque converter locks I lose 300 rpm and it really feels and sounds like you switched gears.
  6. Jan 14, 2013 at 6:19 AM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    That's what I was thinking. So our 1st gens DO have locking torque converters?
  7. Jan 14, 2013 at 6:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yup.
  8. Jan 14, 2013 at 7:17 AM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Thanks!
  9. Jan 15, 2013 at 6:59 AM
    BamaToy1997
    Bill
    Navarre, FL
    Looks like I was late to this party. All the info is spot-on for what was being felt. All normal.
