Couple of Questions...Hope they haven't been asked already.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imjustabill1970, Oct 10, 2017.
  1. Oct 10, 2017 at 10:01 AM
    imjustabill1970
    imjustabill1970 [OP] Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    1. What gear do you normally drive in for regular daily driving? I know that we have the option of changing gears using that S +/- function. Just wondering what the recommended gear is and what everyone is driving in.
    2. Is there a way to increase the tension on the tailgate?
    Later.
  2. Oct 10, 2017 at 10:05 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I use the gear that is most appropriate for the correct speed.
    In my Neighborhood around 20mph I am in 2nd gear
    On highway at 80mph I am in 6th gear
    In the studio parking lot at work I am in 1st and 2nd
  3. Oct 10, 2017 at 10:06 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    1) D mode with ECT on
    2) you want the tailgate to drop slower??
    ChadsPride likes this.
  4. Oct 10, 2017 at 10:15 AM
    imjustabill1970
    bill
    clarksville, tn
    Yes.
    I also think there is some confusion on my question, and that's probably my fault.
    Auto Transmission - When I move the gearshift (while in D) over to the S, I can change the gear and then return it to D for driving.
    Thanks,
  5. Oct 10, 2017 at 10:40 AM
    TacomaDave890
    TacomaDave890 Active Member
    2017 Tacoma TRD Sport DCSB 2WD
    In S mode, I think most people prefer to drive in 5 on normal roads (45 mph) which would cause the engine to stick closer to 1500 rpm instead of 1100 rpm which would increase responsiveness when you give it more gas. In 6 you would use less gas, so I prefer to stay there, however there is no denying the benefits of riding around in 5.
  6. Oct 10, 2017 at 11:19 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I only had a manual trans, but I don't think the S mode in this truck is you choosing a gear. I think it is more of choosing the highest gear that the trans will shift to. But someone might correct me.
  7. Oct 10, 2017 at 11:24 AM
    TacomaDave890
    Aero90, I think you are correct. It will downshift for you when you brake, but it will not shift into a higher gear than what it says on the display.
  8. Oct 13, 2017 at 7:57 AM
    imjustabill1970
    bill
    clarksville, tn
    Okay, what about this one? Is there a way to make it go just a little slower?
    Later.
  9. Oct 13, 2017 at 8:03 AM
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    1) Most city driving I am in 4th in sport mode with ect on. Hell sometimes I'm in 4th on the freeway 'cause WA state has sh****y drivers so I live in the higher rpm's ha ha, but most of the time on freeway I am in 5th
    2) Not sure on this one - I don't have any issues with the rate or it slamming open on me. The cover is real easy to take off (just a bunch of hex screws) so you could take cover off to see if there is any adjustability
    imjustabill1970[OP] likes this.
