couple of questions
Discussion in '4 Cylinder' started by jeff1304, Jun 24, 2009.
  1. Jun 24, 2009 at 12:10 AM
    jeff1304
    jeff1304 [OP] Well-Known Member
    Las vegas
    09 Single Cab 4x4 SR5
    Well i have been shopping for a new vehicle for a while and im thinking a Toyota pickup will be my choice.
    1. But i was curious if i should go I4 or V6 ? this will be a daily driver with some hauling sometimes of nothing more than 600lbs.
    2. Next is what engines do the 2004s have in them ?
    3. Should i go 05 or 04 or maybe some other year ?
    4. what could i expect to find on a budget of 10k-13k ?
  2. Jun 24, 2009 at 12:43 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    well the regular cabs only come with 4 cylinders....but hauling 600lbs would be easy to do with the 4 cylinder.....you will get better gas mileage too and it will be cheaper to buy a 4 cylinder....05 is when they changed to the new body style of the tacoma so you would need to decide if you like the look of the older style or the newer style...i saw an 03 for $8500 awhile back with a little over 100k miles on it....but it had rust on it pretty bad and stuff....i think you can get extended cabs with 4 cylinders too but some are v6....but i think all the double cabs are v6...at least that's how the new ones are....not sure about the 04 and 05's but i figure it's the same..then you have to decide if you want manual or automatic tranny....4wd or not...so on and so forth...good luck with your search
  3. Jun 24, 2009 at 12:50 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I had a 04 regular cab prerunner and traded it in for my 05 Dbl Cab TRD Prerunner. I gotta say I like the 4.0 V6 and the extra room... don't buy something you won't use cause thats just a waste of money. Either old or new you can still do some sweet mods :) Go to autotrader.com. With this economy i'm sure you could get a kick a$$ deal
  4. Jun 24, 2009 at 12:53 AM
    jeff1304
    Las vegas
    this will also be used for hunting some of it not the best weather in the world as well. but im going 4x4 and manual for sure. which years had the 22r engine in them and are they any different than 22re ?
  5. Jun 24, 2009 at 3:18 AM
    Nexxus6
    Nexxus6 Member
    Topsham, Maine
    04 Tacoma 4X4 SR5
    K&N Air Filter PowerSlot rotors Hawk HPS brake pads
    Here is my 04 SR5 4X4. Has a 2.7L engine, 5 speed manual shift. I get about 24 mpg. Paid $12K for it last week.
  6. Jun 24, 2009 at 12:28 PM
    kilgoja
    Alabama
    :mudding:
    the 22 engines are on really old toyota trucks....my old 1988 had the 22re engine...the e stands for efi...electronic fuel injectioin
  7. Jun 24, 2009 at 1:01 PM
    jeff1304
    Las vegas
    what engine does the 04 have ?
  8. Jun 24, 2009 at 1:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    I believe they stopped putting them in in 95
    2.7L or 3.4L
  9. Jun 24, 2009 at 8:52 PM
    jeff1304
    Las vegas
    but does it have any sort of nickname for the 04 engine ?
  10. Jun 24, 2009 at 8:54 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    The older 2.7's are the 3rz
    idk about the 3.4's
  11. Jun 24, 2009 at 8:56 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    x2
    the 22r and 22re are both engineering masterpieces
    dont forget the 2.4L
  12. Jun 24, 2009 at 8:59 PM
    JimBeam
    JB
    2015 Tundra
    from wiki
    95.5-04
    05+
  13. Jun 24, 2009 at 9:01 PM
    JimBeam
    JB
    2015 Tundra
    22r/22re/22rte
  14. Jun 24, 2009 at 9:08 PM
    kroggy
    kroggy Well-Known Member
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Grill Guard. PIAA 520's. And ...
    The 3.4 v6 is a 5vz. 2.7 is 3rz. 2.4 is 2rz.
    On to your other questions. I've had my truck for 3 years now. Hunted in it for all of them. Had an 800 lb elk in it, and all I can say is the truck handled it great, I even had more traction. I would say hunting is all in the tires, good tires will get you places (and get you out). I would say that unless you plan on doing anything where you would need more power, the 2.7 will be fine on an 01-04. I've pulled two four wheelers (weighs in at around 2000lbs +) and never had a problem, your not gonna pull it like a V8 or deisel but you can get the job done.
    Good luck with the search!
  15. Jun 24, 2009 at 9:12 PM
    jeff1304
    Las vegas
    what came with the TRD package on the 02s ? im thinking i might go a lil older to have a lil extra money to buy some accessories.
  16. Jun 24, 2009 at 9:16 PM
    JimBeam
    JB
    2015 Tundra
    TRD came with an elocker in the rear axle and upgraded shocks and front coils
  17. Jun 24, 2009 at 9:22 PM
    kroggy
    Idaho Falls, ID
    04 TRD 3.4 4x4
    According to wiki & tigerfans previos post, might need the V6 for the locker. Sure someone on here would know for sure.
  18. Jun 24, 2009 at 10:33 PM
    jeff1304
    Las vegas
    also for the TRD suspension is it produced by bilstein like the newer ones ?
  19. Jun 25, 2009 at 5:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    And an extra leaf I think
    TRD was available in 4 cylinders also, the 3RZ to be exact.
    The 2RZ was in the 2wd tacomas.
  20. Jun 25, 2009 at 6:20 PM
    jeff1304
    Las vegas
    ok im still trying to decide between getting a 04 or getting a 02 but with the 02 i spend the money i save to add on things what would all of you do ?
    currently looking at going 4cyl extended cab with trd package
