Couple of Quick Retrofitting questions
Discussion in 'Lighting' started by Team Flatline, Oct 3, 2016.
  1. Oct 3, 2016 at 7:34 AM
    Team Flatline
    Team Flatline [OP] Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    I'm in the process of my first retrofit on my 2012 and have come across a couple of things that I have to ask about. I'm installing the Mini D2S-X projectors (square lens) with Gatling Gun shrouds and the Morimoto Elite HID system.
    The first question might seem stupid but which way is "Up" on these things? I assume that the "flat part of the projector" is "up" for cutoff, but need to make sure.
    And next, the Gatling Gun shrouds when installed, leave about a 3/16" gap between themselves and the headlight bowl. Is this normal?
    Thanks,
    Eric
  2. Oct 4, 2016 at 4:20 PM
    Team Flatline
    Eric
    Up a creek, Fla
    PreRunner
    Knock knock, anybody home?
  3. Oct 4, 2016 at 6:40 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I can't speak for the shroud but the cutoff shield always goes on the bottom.
  4. Oct 4, 2016 at 6:43 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The flat cutoff shield in the projector will always be on bottom. PLEASE BENCH TEST YOUR EQUIPMENT BEFORE PUTTING BACK TOGETHER. It will save you a lot of heartache later.
    Also it is normal for the shrouds to have a gap on the backside on these trucks. They are universal parts and the tacoma has a very deep reflector bowl.
  5. Oct 4, 2016 at 7:46 PM
    Team Flatline
    Eric
    Up a creek, Fla
    PreRunner
    Many thanks gentlemen. I'd of damn sure done it just the opposite after looking at all the beam pattern cut-off shots that show a nice flat "line" (oops, no pun intended). Colton, I think I'll fab up something to close the gap to satisfy my OCD. :thumbsup::thumbsup: to both of you.
