Couple Questions After BHLM and Retrofit
Discussion in 'Lighting' started by iJDub, Dec 8, 2013.
  1. Dec 8, 2013 at 2:44 PM
    iJDub
    iJDub [OP] Well-Known Member
    So I did the BHLM / Retrofit with some Depo headlights...couple things/issues/concerns:
    1) The black bezel after I painted it back, when I set it back into the clear lens, it made contact with the lens at 2 points and the paint rubbed/distorted. Very minor and small - I can live with it. Is this just an issue with aftermarket headlight quality/tolerances?
    2) Once I put the Retrofit H4 projectors in and the bulb, when I went to slip on the black rubber boot, I noticed technically it's not 100% sealed...moisture can still get in (and out I suppose) through it...is that normal? Should I put some silicone there to seal it up?
    Other than that I'm very happy with results.
