Couple questions on 05 DC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by irishpride42, Oct 14, 2008.
  1. Oct 14, 2008 at 4:48 PM
    irishpride42
    irishpride42 [OP] Well-Known Member
    NC
    05 DC 4WD
    I noticed some people (example:neontrail sorry to call you out) did a seatbelt ding mod. The Taco I bought Friday does not ding except when you start the truck and that's it, is this a mod or normal? The other things when I lock the doors with the remote it doesn't beep and also with the passenger side airbag the manual says there should be a "keyhole" to turn it off however I know it has the sensor so if you put a child seat for example will it turn off?
    Thanks guys!
  2. Oct 14, 2008 at 4:52 PM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    in my truck when i don't have my seatbelt on it doesn't ding, just flashes the light so i'm not sure about that. the keyless entry that i'm guessing came with your truck is not an actual alarm system so it won't beep. when you hear cars beep when locked that generally means that the alarm is set but on the stock keyless entry it doesn't come with an alarm so you will just see your lights flash. and with the airbag system in the DC, since you have a real back seat, it has a weight sensor so it automatically goes on or off depending on if you have stuff in the passenger seat or not, no need for a keyhole to manually turn it on or off
  3. Oct 14, 2008 at 4:59 PM
    irishpride42
    NC
    05 DC 4WD
    From my understanding it does have an alarm system, hell it even has the stickers on both windows LOL!
  4. Oct 14, 2008 at 5:00 PM
    MsTRD
    Samantha
    Rohnert Park, CA
    i don't know then. i had the same question when i got my truck and the answers i got were what i told you...
  5. Oct 14, 2008 at 5:12 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    the seatbelt ding mod is for the 08 and 09's that will constantly ding if u drive off w/o the seatbelt engaged. u wont have a lock/unlock beep on the 05...thats on the 09's unless u mod it....and u wont have the passenger side airbag cutoff in the DC b/c there is a sensor in the seat that determines if there is enough weight for the airbag to be turned on at all. if u look right below the radio, u should see "AIRBAG" and then on or off...will let u know what state its in
  6. Oct 14, 2008 at 5:24 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    you can usually change the beep when locking or unlocking. check the manual for settings on how to change it.
  7. Oct 14, 2008 at 6:13 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    It has an engine immobilizer from the factory and that may be what the stickers are for.
    My '05 with keyless entry didn't beep, it didn't have the beeper mechanism. My '06 with keyless entry doesn't beep either, and still doesn't beep even after I installed the OEM VIP RS3200+ security system, again lacks the beeper mechanism.
    Marc M
