Couple questions on 2007 4Runner
Discussion in '4Runners' started by CNEDEER, Jan 27, 2014.
  1. Jan 27, 2014 at 5:14 PM
    CNEDEER
    CNEDEER [OP] If ya ain't first, your last!
    2015 DC TRD OR 4x4
    My mom just bought a 2007 Toyota 4runner 4WD Sport. I had created a thread prior to this with issues regarding the rear hatch not opening, but I have a few other questions about it.
    1) It has a button next to the RSCA button (Left of it) that has a small 4-wheel diagram, is this the differential button? When I press it, nothing happens??
    2) When I engage it into 4WD, it goes into place, however, the "VSC OFF" stays on the dash...is this normal????
    3)Probably most importantly, there is a rear-end noise coming from the back. Almost sounds as if you were turning rotors in a shop, perhaps maybe a growling noise (wheel bearing, maybe?). Hoping that it is something simple.
    Thanks in advance!
  2. Jan 30, 2014 at 7:08 PM
    kevinpt3
    kevinpt3 4runner *****
    Kevin
    Richmond VA
    09 4runner limited
    4th gens have AWD(torsen diff) , so you can be in 4hi or 4low with center diff open.
  3. Jan 31, 2014 at 7:02 PM
    CNEDEER
    2015 DC TRD OR 4x4
    So is that the diff button then, is that what you mean lol?
  4. Feb 1, 2014 at 7:49 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yup, center diff lock.
  5. Feb 1, 2014 at 7:54 PM
    CNEDEER
    2015 DC TRD OR 4x4
    gotcha. not very familiar with it. can it only be engaged when in 4wd?
  6. Feb 1, 2014 at 8:17 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Correct, both hi and lo.
  7. Feb 1, 2014 at 8:20 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    It basically makes the system like a "normal" 4wd system, ie don't lock it on pavement, 50/50 power split. 4wd without the center diff locked you can drive on pavement all day, you could even leave it in 4 hi for the test of the vehicles existence if so desired.
  8. Feb 2, 2014 at 9:44 AM
    CNEDEER
    2015 DC TRD OR 4x4
    great info! thanks! any reason the VSC OFF light would be coming on when I engage the 4wd.
  9. Feb 2, 2014 at 2:45 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    That should only happen when you lock the center diff. Are you saying it comes on when switching the dial from 2wd>4wd?
  10. Feb 2, 2014 at 8:14 PM
    CNEDEER
    2015 DC TRD OR 4x4
    yes, when i switch from 2wd to 4hi, the vsc off light appears...maybe because the center diff button was already pressed? ill have to upload a picture of it when i get a chance.
