Course Motorsports 3rd Gen. Tacoma Direct Fit Cell Phone Mount
Discussion in 'Product Reviews' started by LivinOnEdge, Oct 24, 2020.
  1. Oct 24, 2020 at 4:50 PM
    LivinOnEdge
    LivinOnEdge [OP] ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    @CourseMotorsports reached out to me to test and review their cell phone mount for 2016+ Tacomas.
    These mounts can be purchased on their website for $45+ shipping at https://coursemotorsports.com/collections/toyota/products/toyota-direct-fit-magnetic-phone-mount
    The kit comes with:
    1. CNC machined and black powdercoated bracket with 3M dash protecting foam
    2. CNC machined and anodized ball mount
    3. Magnetic rubber capped phone mount
    4. 1 circular/1 rectangular metal adhesive backed receivers
    Installation was super simple. Taking roughly only 4 minutes of my time. Simply grab the right hand corner of the dash trim, give it one good tug and it will begin to pop off.
    With a 10mm ratchet, remove the 4 bolts holding the radio head unit into place.
    Pull out the head unit just enough to get the mount behind the radio mount and reuse the bolts to attach it.
    Tighten all the bolts and replace the dash trim.
    Attach one of the adhesive metal plates to the back of your phone or phone case. (Note: I tried putting the plate on the inside of my phone case and although the magnet is able to still make contact, I would not trust my phone to stay in place over a bump)
    The magnetic phone mount holds strong to the metal backing, even on a larger, heavier phone like my Iphone.
    Overall, I really enjoy how low profile this mount is. Its out of the way of my air vents and still in a visible position. It doesn't obstruct my view while driving and the magnetic base provides me a quick on and off capability.
    Thank you @CourseMotorsports for allowing me to review your outstanding product!
  2. Oct 24, 2020 at 9:09 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    One thing I didn’t see in your video was how the phone can be tilted left-right, up-down. With the ball and collar design I assume it can be, correct?
  3. Oct 25, 2020 at 5:31 AM
    LivinOnEdge
    Land of The Lost
    Yes, this can be rotated.
    davidstacoma[QUOTED] likes this.
  4. Oct 25, 2020 at 5:46 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Looks like a clean install tbh. Nice
  5. Oct 25, 2020 at 5:51 AM
    elmontemike
    elmontemike Well-Known Member
    Looks good. Does the metal plate affect the wireless charging?
  6. Oct 25, 2020 at 6:34 AM
    LivinOnEdge
    Land of The Lost
    I have not tested this. I can only assume it would since the magnetic field needed to generate the charge will be obscured by a metal plate.
  7. Nov 20, 2020 at 11:30 AM
    Grizzwald
    Grizzwald New Member
    2020 Tacoma TRD
    Looks sweet, I was about to order one but at $25 to ship to Canada plus the $45 and then the exchange rate I think I 'll try to make one.
    LivinOnEdge[OP] likes this.
  8. Nov 30, 2020 at 6:06 AM
    Westsideott
    Westsideott Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    I'm in Canada too and can't stomach the shipping and xrate but really like the minimalist look....if you do end up making one, please post pics!!
  9. Mar 9, 2021 at 6:09 PM
    Time Chaser
    Time Chaser New Member
    chris
    2021 Off-Road Access Cab
    I wonder if you could mount that on the bottom right hand side of the head unit. That way there would not be much cable running across the dash.
  10. Mar 14, 2021 at 7:14 AM
    LightningTuned
    LightningTuned Member
    2016 Tacoma SR5 4x4 Inferno
    I like how this does not obstruct the air vent at all, but I've never been a fan of magnetic mounts because its takes away the ability for wireless charging. It would be pretty cool if they could incorporate the same perfect squeeze mount that hondo uses.
  11. Apr 14, 2021 at 1:39 PM
    TheBlueTacoMan
    TheBlueTacoMan Member
    Northern Colorado
    2018 Tacoma TRD OR in Blue
    I got mine today and the magnet wont quite work with my phone case. I guess I'll have to use a ball mount cradle from another system.
  12. Apr 15, 2021 at 10:54 AM
    LivinOnEdge
    Land of The Lost
    I stuck the magnet outside of my case. I didn't want to at first but committed. Now I don't even care. Nicer to just drop my phone on the mount.
  13. Apr 18, 2021 at 1:12 AM
    310tacoma
    310tacoma Well-Known Member
    Jose
    Gray Tacoma
    Hey dude is that a 1” ball would that work with a ram arm?
