courtesy/entry lights
Discussion in 'Lighting' started by totmacher, Sep 10, 2009.
  1. Sep 10, 2009 at 11:26 PM
    totmacher
    totmacher [OP] automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Spent the day trying to get the wiring just right and had to scrap my original plan because I couldn't get the right signal. But, I finally got an exterior light to sync with the dome light so when I unlock using the keyless entry fob, I get exterior light in addition to the dome light (normal operation is dome light only). It actually comes on any time the dome light does.
    pics attached.
    It's just 1 very bright LED mounted into the bottom of the driver side mirror arm. Pics were taken inside my garage with doors shut and all other lights out.
  2. Sep 10, 2009 at 11:27 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Great job! looks great.
  3. Sep 10, 2009 at 11:46 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    thats sweet man! do a full writeup if you can
  4. Sep 11, 2009 at 4:07 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    thats cool looking!
  5. Sep 11, 2009 at 4:09 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    writeup! writeup! lol what kind of LED did u use?
  6. Sep 11, 2009 at 4:44 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Please tell us what brand name and type model number for the LED light, also will you have a few more photos where did you tap the power signal wire from. This will be a great help. Thanks
  7. Sep 15, 2009 at 6:53 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    The light is from Oznium. It's a white "pre-wired superflux 4-chip LED". Cost $2.99 each I think. I've got some red ones under the dash to light the floor. Very bright lights. It only took 1 of the red ones to light up the floorboards (1 on driver side + 1 on passenger).
    The short description is that I drilled a 5/16" hole in the mirror bracket (wallowed slightly until I had a snug fit for the LED housing). Used a sharp knife to carefully nick the sleeve covering the power mirror wires and fed my LED wires through the sleeve until they came out near the mirror plug. Fed the wires through the door and into the kick panel under the dash (just followed the other bundle of wires and taped/tied to it so my wires wouldn't get cought on the window when it lowered). Then fed wires up into the pillar and into the headliner at the dome light. Had to remove the trim on the pillar (grab handle too) and along the top of the door (so I could pull down the edge of the headliner). Then I soldered my LED wires to the dome light bulb contacts. I also put an inline 4 amp fuse on my lights. The dome itself is fused with a 7.5A in the main fusebox but I felt better fusing my own work too just in case. I put my fuse holder behind the grab handle trim on the pillar.
    Oh, I put a few layers of heavy duty electrical tape on the metal support bar that crosses the roof directly above the dome light. This is so that my wires don't get rubbed and eventually short there because my wires do stick out of the back side of the dome housing right where the metal bar is in the roof. I put a piece of tape directly over the wire on the housing as well.
    Just note that I tried to splice into the dome lights wires at the front pillar but it just wouldn't work correctly. There might be something tricky in how the computer (BCM i think) sends its signal to the switch at the dome.
    This light comes on anytime the dome is on.
    I'm working on getting the passenger side light put in now. I'm just going to route the wire under the dash and splice in at my inline fuse. Some zip ties should keep my wires out of the way of everything else under the dash.
  8. Sep 15, 2009 at 6:54 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    This is what it looks like when it's off. My opinion is that you don't notice it you don't know it's there already.
  9. Sep 19, 2009 at 4:36 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    this needs to be in cheap/free mods section!
  10. Sep 19, 2009 at 4:50 PM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    thats awesome. might just be my next mod!!
  11. Sep 19, 2009 at 5:34 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    pretty awesome
  12. Sep 19, 2009 at 6:19 PM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    Looks awesome:D
  13. Nov 23, 2009 at 4:10 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    got my LEDs, same ones you have. gonna be attempting this over the holiday weekend. i got 4 of them so i may put the other 2 mounted to my step bar at the rear doors. we will see how it looks at to whether they stay there. wish me luck.
  14. Nov 23, 2009 at 4:16 PM
    G-Sak
    G-Sak Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    Very cool, subscribed!
  15. Nov 24, 2009 at 5:45 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Could you explain in detail what I would need to do the lights to light up the floor, what wire harness should I order and what length LED strip did you use, and how long did it take to install, and do I need to do any removal of the dash?
    I would really appreciate it man thanks.
  16. Nov 24, 2009 at 6:10 PM
    dlthunder
    dlthunder Well-Known Member
    Dan
    Reno, NV
    Sold my Taco
    TRD Skid Plate Rear Seat 11inch DVD Toyota Bed Mat Pace Edwards Full Metal Jackrabbit Nerf Bars Tailgate Electric Dynolock D-ring Bedbolts
    Does anyone know how you can tap into the dome light without running a wire up to the light itself? I wanted to add some under dash lights that will go on with my dome light but didn't want to have to get into the liner and mess with the overhead DVD player.
  17. Nov 28, 2009 at 5:40 AM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    I chose to mount the lights on my step bar. Worked out well i think.
  18. Nov 28, 2009 at 1:21 PM
    music_man185
    music_man185 Active Member
    NC
    07 Black Double Cab, SR5, 4x4
    isn't drilling a hole to mount a light in the step bar a little risky? what i mean is, wont it make your step bars more prone to rust?
  19. Nov 28, 2009 at 1:27 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    maybe, we will see. if i see rust start appearing then i will removed the lights and seal the metal with paint or something. they are just step tubes after all. if nothing else i could completely remove them.
  20. Nov 28, 2009 at 1:28 PM
    Mr. T
    Mr. T Well-Known Member
    Gulf Coast, Texas
    06 4x4 SR5 Black
    Very cool post...I like what you've done!
