2nd Gen Courtesy/Runnging Board Lights Mod
Discussion in 'Lighting' started by bigfoote13, Aug 16, 2016.
  1. Sep 14, 2016 at 9:07 AM
    caribe makaira
    Caribbean, Puerto Rico
    According to whom?o_O In the 05-15 it's a ground..on the asked post #5 he has a '16...read the whole thread:rofl:
  2. Sep 14, 2016 at 9:08 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Oh, got it, you didn't understand what I said.
    If you're going to add a fuse in front of 4 new lights like the OP has proposed in his circuit he doesn't need to know the rest of the light's current draw. He's fusing in front of the added lights as they're run direct to battery. He's using a relay behind the negative side running off the dome light to cycle the coil.
    So, just to be a little overly pedantic, 1amp LED's become pretty elementry math: 1x4=4amps * .30 = 5.2amps
    I'd put a 5amp fuse in front of the new LEDs and call it a day. If you blow it more than once, review connections for shorts and consider replacing with larger. The initial draw on an LED is low compared to a halogen or HID.
    ChadsPride likes this.
  3. Sep 14, 2016 at 9:10 AM
    caribe makaira
    In his drawing there is no relay...it's a DPDT switch...
  4. Sep 14, 2016 at 9:11 AM
    digitaLbraVo
    Touche. I'm used to seeing SPDT in the context of a relay.
    I'll take it, since you didn't address the rest of the post, you have nothing to add.
  5. Sep 14, 2016 at 9:12 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    My bad, didn't see that asshole. :rofl:
  6. Sep 14, 2016 at 9:13 AM
    caribe makaira
    Asshole? Everyone has one...or is one...
  7. Sep 14, 2016 at 9:49 AM
    caribe makaira
    You lost me...nothing to add? I pointed out the switch so you could revise your statement...let's go back to what the OP wants to do so others may duplicate or not. When the dpdt switch selects the dimming circuit ('15 is Neg) he's adding the lamp load to an unknown amp max. In his vehicle he may have 5 lamps (incandescent lets say 1 amp each) and the OP didn't add any specs of his added lamps. So the suggestion went: Change all your interior lights to LED's to lower the draw on the OEM circuit...
  8. Sep 14, 2016 at 10:49 AM
    bigfoote13
    bigfoote13 [OP] Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    So what way should I do this on my 15? My original post?
  9. Sep 14, 2016 at 12:12 PM
    caribe makaira
    Yes, your original post is fine. Just keep in mind that the interior light circuit has a 7.5 amp protection. If you change the OEM lamps to L.E.D.'s (Dome, Maps, Vanity) then the circuit could handle the added "courtesy lights" if they are L.E.D's also or incandescent and don't exceed the combined total amps.
    Too much?
  10. Sep 14, 2016 at 12:37 PM
    caribe makaira
    In reality the only lamp that is tied into the dimming circuit is the dome festoon which is about 1 amp. I have the maps and dome tied into the dimming on my '05 since new, no issues. Also have 2 LED as curb/courtesy lamps on same circuit with a DPDT switch and they are ON with the turn signals '70 style. These are 5 amps combined. Like I mentioned.. I have no idea the max amps the dimming circuit can handle without issues.
  11. Sep 28, 2016 at 10:23 AM
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    I was reading through this thread I am wanting to do the same sort of thing where do I tap in to the ground for the dome light?
  12. Sep 28, 2016 at 12:17 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
  13. Sep 28, 2016 at 12:18 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
  14. Sep 28, 2016 at 12:59 PM
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    thank you did you just use a wire tap?I see that you were going to use a switch I wonder if I can not use the switch and just tap the dome ground and just run the power form the battery?
  15. Sep 28, 2016 at 1:11 PM
    #35
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I haven't done it yet. I am going to tap the dome in the drivers A-pillar. You can power straight from the battery.
    No need for the switch if you only want them on with the key fob. I wanted to be able to turn them on whenever i wanted and a SPDT will let me do that.
  16. Sep 28, 2016 at 1:12 PM
    #36
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I think the next thing is putting a switch in so i can look turn on the rear camera on whenever.
    ChadsPride and Caprizzy like this.
  17. Sep 28, 2016 at 1:14 PM
    #37
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    I haven't decided if I want to go the switch route it would probably come in handy.
  18. Sep 28, 2016 at 1:16 PM
    #38
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Why not. All it is a switch and an additional ground wire. Might as well do it.
  19. Sep 28, 2016 at 1:17 PM
    #39
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Agreed are you doing bed lights as well?
  20. Sep 28, 2016 at 1:18 PM
    #40
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Probably not until i find a need for them. So far I haven't.
