Cowl induction snorkel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badger, Dec 22, 2017.
  1. Aug 27, 2019 at 2:35 PM
    #41
    eon_blue
    Azusa, CA
    If a smog shop won't pass you because of a snorkel then you need to go to another shop. The snorkel is just an extension of your air intake, it has no effect on emissions. Anything after the MAF sensor is what they pay attention to and where you need CARB certified parts.
    Taco-Obsessed[QUOTED] likes this.
  2. Aug 27, 2019 at 2:38 PM
    #42
    eon_blue
    Azusa, CA
    As long as the MAF sensor is still there in it's stock location and isn't messed with then it shouldn't matter, only reason I can think of why some smog shops might be saying this is because they don't know any better and are trying to cover their ass. It's a big fine from the state if they get caught passing someone that should have failed, and I highly doubt they know exactly what is/isn't allowed when it comes to modifications on every vehicle. To some of them it's probably just safer to say 'that's not legal' if its not OEM.
    GilbertOz and mojojojo78 like this.
  3. Sep 3, 2019 at 8:04 AM
    #43
    craiger4233
    craiger4233 Active Member
    houston texas
    05 4dr 4wd lb
    Would someone explain the purpose of a snorkel. I missed the boat on this upgrade.
  4. Sep 3, 2019 at 8:58 AM
    #44
    eon_blue
    Azusa, CA
    Extends your air intake higher up which is good for a number of reasons - cleaner air on dusty trails, less likely to take in water if you're crossing water deeper than the tires or hitting smaller water crossings with speed, and you get much cooler air from way outside the engine bay/wheel well area. Cooler air = lower intake air temps and better performance
  5. Sep 3, 2019 at 9:01 AM
    #45
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Theoretically this is correct.
    In practice smog shops are very, very leery of anything modified. CARB has a very extensive undercover operation that exists purely to trip up smog techs and the penalties can be harsh, up to and including jail time.
    My truck (with a TRD intake and a snorkel) passed without issue a few weeks ago.
    GilbertOz and eon_blue[QUOTED] like this.
  6. Sep 3, 2019 at 9:03 AM
    #46
    eon_blue
    Azusa, CA
    I'm hoping mine does, I just added a snorkel last year. I'm going to go back to the same shop that I went to last time, they were pretty impressed with my truck (supercharger and all) because it had all the right CARB stickers and whatnot. Hopefully the snorkel is no big deal. Also chopped my exhaust at the rear axle which I hear shouldn't be a problem (since it's after the cats) but we'll see.
  7. Sep 3, 2019 at 9:04 AM
    #47
    Richie Rich
    760 (San Diego)
    Exhaust on mine is chopped too (high clearance rear bumper). No problem (stock exhaust, lopped off right after the rear axle, all cats and factory muffler intact.)
    eon_blue[QUOTED] likes this.
  8. Sep 12, 2019 at 12:55 PM
    #48
    Darklight
    Darklight Well-Known Member
    Bobby
    Charlotte,NC
    2008 Black SR5 V6 4Runner
    http://www.toyota120.com/forum/showthread.php?t=26920
    Hope you don't mind me sharing this info with other Toyota folks :)
    Question, what size hole did you cut for the 3" intake tubing? I see most used a 4" and then a 4" tubing but plan to go your route,
    #48
  9. Sep 12, 2019 at 1:47 PM
    #49
    badger
    badger [OP] Well-Known Member
    07 SR5
    Not at all! This is an open forum for the free exchange of ideas. I cut a 3-1/4" hole, so the rubber hose used as a grommet had room. Using a 4" tube is not a good idea, because it locates the bottom of the tube too close to the bottom of the gutter. You need a 3" tube mounted high in the gutter. If you read around, there are a few people who have complained of some water getting into intake with this mod. I'd make a substantial bet that those people have 4" intake tubes, or tubes that enter the cowl area too low.
  10. Sep 12, 2019 at 6:49 PM
    #50
    Darklight
    Bobby
    Charlotte,NC
    Thanks man! I’m on the fence on ordering intake parts or chopping up the stock tubing and making use of it.
    Bobby
  11. Sep 12, 2019 at 7:25 PM
    #51
    badger
    07 SR5
    The parts are cheap, and just easier.
  12. Sep 13, 2019 at 5:54 AM
    #52
    Darklight
    Bobby
    Charlotte,NC
    True I have been looking at this place and plan to order parts. https://www.intakehoses.com/ total is like $50 maybe I should look at Amazon,lol.
    Maybe we can do a community hole saw swap for folks installing these?
    Taco-Obsessed likes this.
  13. Sep 13, 2019 at 11:46 AM
    #53
    Darklight
    Bobby
    Charlotte,NC
    Parts ordered thanks for the advise @badger Wishbone Runner, James talked me into doing this a long time ago just never did it haha.
    Bobby
    badger[OP] likes this.
  14. Sep 14, 2019 at 9:21 PM
    #54
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    So I just found this.
    I don't see a lot of airflow into the cowl area on my truck. Are there hidden area that allow inflow of air?
  15. Sep 14, 2019 at 9:25 PM
    #55
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    #55
    RA77, Slashaar, dborrer and 2 others like this.
  16. Sep 15, 2019 at 6:34 AM
    #56
    badger
    07 SR5
    Read the first post
  17. Sep 15, 2019 at 4:43 PM
    #57
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It draws from both wheel wells at the ends plus slotted vents in the cowl cover. Available cross sectional area is much greater than the duct.
    RA77 and Taco-Obsessed like this.
  18. Oct 5, 2019 at 7:05 PM
    #58
    cwadej
    Right Here
    2011 Access Cab 4x4
    Did this today. I saw in the other thread someone used a hole saw set from Harbor Freight. His truck must have been made of warm butter, mine barely got scratched with the HF junk.
    I cut about 1/4" of the elbow off the 4" end, all lined up better that way. about 1.5" off the AL tube also. I used an old license plate to cover the cabin air intake, angled from the glass to the inlet.
    quick test drive shows no issues
    Northbound_Taco likes this.
  19. Oct 5, 2019 at 7:07 PM
    #59
    eon_blue
    Azusa, CA
    The Harbor Freight hole saw kit is junk...at least for doing a snorkel on our trucks. I bought that kit and all it did was scrape the paint off my fender (I installed a regular snorkel)...wouldn't even cut into the metal. Went out and bought a Milwaukee hole saw from Home Depot and it cut a perfect hole out in 2 seconds.
    GilbertOz likes this.
  20. Dec 27, 2019 at 7:11 AM
    #60
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    how you guys liking this snorkel? Any problems or anything?
