Cr125 2 stroke help !!!!
Discussion in 'Motorcycles' started by Unknown, Nov 25, 2010.
  1. Nov 25, 2010 at 8:48 PM
    Unknown
    Unknown [OP] He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    :help:
    Im looking at my cousin's 2002 CR125, but the kickstart is loose, i have turn it over with my hand and it doesnt start, what does that mean?
    Low compression maybe? Topend?
    Oh he wants 350 for it, pretty clean to, FMF exhaust, ASV levers , Exels gold color :cool:
  2. Nov 25, 2010 at 9:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Wait, is the kick starter loose on its shaft? Or is the motor just really easy to turn over?
  3. Nov 25, 2010 at 9:03 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    its doest start at all, by loose i meant i could push it down with my hand. nothing like my 4 stroke.
  4. Nov 25, 2010 at 9:06 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    take the spark plug out and put your finger over the cylnder and crank over listen for air throught the exhaust and where your finger is should be able to tell if she has compression.....
    assuming you have no comp tester
    also 2 strokes FTMFW
  5. Nov 25, 2010 at 9:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Well a 125 2 stroke is going to be easy to start compared to your 4 stroke, but it sounds like low compression. It at the very least needs a new top end or worst case also needing the bottom end rebuilt. It won't be over 500 to fix at the very most. More likely around 130 to get it running.
  6. Nov 25, 2010 at 9:09 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    Nope i dont have a comp tester :eek:
    500 scares me, i can do 150 though. the only reason im interested is because im getting for 300 and i can make $ of it after i sell it :D
  7. Nov 25, 2010 at 9:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah you'll know if the bottom is going too when you get the cylinder off by seeing if there is play in the bearing where the rod connects to the crank. Those usually last a long time though if you run the right 2t oil.
  8. Nov 25, 2010 at 9:13 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I had a buddy who could start his 125 with his hand. I'm going with low compression as well.
  9. Nov 25, 2010 at 9:14 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    cause he said it had a new top end, but said the kick start is messed up?:confused:
    Bull?
  10. Nov 25, 2010 at 9:16 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    oh, maybe there is something wrong with the idler gear on the kick starter. You need to make sure the piston is actually moving up and down when you push the kick starter down. Also see if you can get it to bump start, if it has a new top end that was installed correctly it will start.
  11. Nov 25, 2010 at 9:17 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    Ok, man these 2 strokes are a pain in the Arse
  12. Nov 25, 2010 at 9:18 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Just wait till you have to do the top end on that 4 stroke:eek: talk about expensive!
  13. Nov 25, 2010 at 9:18 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    can it be the crank?
  14. Nov 25, 2010 at 9:19 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    im changing my oil every 2 rides :D seriously though :eek:
  15. Nov 25, 2010 at 9:20 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    nah, the crank usually just seizes which would mean the kick starter wouldn't even move.
    You might want to try posting this over on thumpertalk, they know their stuff.
  16. Nov 25, 2010 at 9:23 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    lol i was searching in there, maybe i will :spy: ......... Im going to try to bump start it if it does start i'll take it if it doesnt , well 2 strokes are NOT the way to go :rolleyes: jk
  17. Nov 25, 2010 at 9:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    lol, sounds good.
  18. Nov 25, 2010 at 9:30 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    2 strokes = 2x's the power and half the moving parts
  19. Nov 25, 2010 at 9:32 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    and 10X the fun!
  20. Nov 25, 2010 at 9:33 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    125=250f ????
