Cr125 2 stroke help !!!!
Discussion in 'Motorcycles' started by Unknown, Nov 25, 2010.
  1. Dec 3, 2010 at 12:33 PM
    #61
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    because its a 250. Mine does it too. Try starting a 500 2t:eek: talk about snapping your leg in half.
  2. Dec 4, 2010 at 10:36 PM
    #62
    Nitronick
    Nitronick Well-Known Member
    Nick
    Oregon City, OR
    98 tacoma sr5 v6 3.4
    yep yep, my 250 also does it!
  3. Dec 6, 2010 at 6:34 PM
    #63
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Did you ever get it running?
  4. Dec 6, 2010 at 6:41 PM
    #64
    Unknown
    Unknown [OP] He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Nope, I changed the oil/gas, tried to bump start and nothing. Went to AutoZone to get a starter fluid and nothing. All i hear is the piston going up and down. FML
  5. Dec 6, 2010 at 9:14 PM
    #65
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I bet either the rings are gone or theres a hole in the piston. Honestly I would pass on it because it was obviously not maintained properly.
  6. Dec 6, 2010 at 9:16 PM
    #66
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    What you mean by "pass on it"
  7. Dec 6, 2010 at 9:17 PM
    #67
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Not buy it.
  8. Dec 6, 2010 at 9:21 PM
    #68
    ktmrider
    Junk
    he already bought it, and its probably going to need a rebuild
  9. Dec 6, 2010 at 9:21 PM
    #69
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2
  10. Dec 6, 2010 at 9:22 PM
    #70
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Oh.
    well it looks like its time to pull the cylinder off and see whats wrong.
  11. Dec 6, 2010 at 9:25 PM
    #71
    Tacomanator
    Clam Slammer
    Southern Cali
    just tear the damn thing apart and go through EVERYTHING. 2 strokes are easy to tear down and re-build.
  12. Dec 6, 2010 at 9:26 PM
    #72
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    Yeah, im taking it to some guy to check it out this week.
    Free estimate :)
  13. Dec 6, 2010 at 9:32 PM
    #73
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    sounds good if its free, but don't pay someone to work on that bike. Its really easy and fun too.
  14. Dec 6, 2010 at 9:36 PM
    #74
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    yeah, especially if im keeping so i can learn ;) But my kx has been so good to me:)
  15. Dec 7, 2010 at 11:55 AM
    #75
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I betcha there is a nickle sized hole in the center of the piston. sucks,,but a easy fix if so. gasket set, piston, cylinder hone or slight bore. a couple hundy total(maybe less), and it should be up and running then.
    The trick is why did it meltdown if it did,,this needs to be found out or at least investigated also,,or you will be right back to square one.
    Did your cousin mess with the jetting in the carb??. if he did mess with it, it needs to be reset to the original factory richness, to break in the piston properly again. That piston, heat expands faster than the cylinder sleeve, and it need to be cooled and lubed right as it wears in again.
  16. Dec 7, 2010 at 12:00 PM
    #76
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    My bike is in the shop right now..fork seals and brakes
  17. Dec 9, 2010 at 7:50 AM
    #77
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    i have an 01 cr125. i love it. once you get it running right, maintain it properly and you will be good to go
  18. Dec 15, 2010 at 11:54 PM
    #78
    GoatFiddyone
    GoatFiddyone Well-Known Member
    Altamonte Springs, FL
    '17 DCLB TRD OR
    I've raced/ ridden damn near every single 125 out there. I've blown up many of 125's in my day. When they go, you know. There is quite a bit of a difference between low compression and no compression. What does the air filter look like? If you can turn it over with your hand and there is no resistance, then it has no compression. On a 125, usually means a broken ring. If you feel the kick starter step, then it has low compression and piston and ring should solve your problem.
    If there is a hole in the piston, someone was getting some detonation for a while. This would be the result of running 87 octane in your 125. This is not very likely but don't put too much faith in humanity. On a 125 the chances are pretty good it will run like total shit before it burns a hole in the piston and said cousin should know.
    I think your cousin was probably someone who mixed oil correctly and rode that bike for a while but never did a ring job at the least.
    Worse case, you need a piston, ring, and cylinder.
    Best case, it needs a piston and ring.
    In the whole grand scheme of things, you are getting a pretty good deal on it.
  19. Dec 16, 2010 at 12:27 AM
    #79
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I was about to say that ^ i raced a cr125 for years, never had a problem with it, just change the top end, mix your gas right and clean the air filter you should be alright.
  20. Dec 29, 2010 at 6:34 PM
    #80
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    update.. got pictures of the piston and cylinder.
