cracked bed tub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Weblefty, Feb 10, 2013.
  1. Feb 15, 2013 at 2:03 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    I might be wrong, but I was under the impression that these beds were so trusted that they offer a lifetime warranty. I was told, if you can break it, they'll fix it for free. Might want to call Toyota dealer and see what they say. If that doesn't work, call Toyota HQ and ask. I'm almost positive the beds are lifetime warranty
  2. Feb 15, 2013 at 2:38 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Toyota isnt so quick to replace the beds. Mine has been going thriugh a warranty check for a few months now and i havnt heard anything yet. Mine is cracked in pretty much same place (will add pics later) but is definatly not as sever as the op.
  3. Feb 15, 2013 at 8:41 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    good idea! :anonymous:
  4. Feb 15, 2013 at 9:02 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the bed is not plastic, nor is it a simple fiberglass.
  5. Feb 15, 2013 at 10:04 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    It is plastic with fibers in it, that is all. It melts fine, believe me :D
  6. Feb 15, 2013 at 3:04 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    OP mine was broken like yours, I took it to a bodyshop and they fixed it doing something similar to this ^^.
  7. Feb 15, 2013 at 8:22 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  8. Feb 16, 2013 at 1:26 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    It looks like they used tie down straps that had hooks and actually put the hooks in between the rear of the cab and bed itself.
    The owner I bought my truck from had a set of straps with hooks in the same spot when I showed up to look at the truck I bought. There is a lip back there that the hooks grab on to nicely but it is just not strong.
    I bet the vending machine was up against the metal rail so they just hooked it behind the bed. You can see the gouge into the bed in the one picture and I am guessing it looks the same on the other side as well.
    That section of bed was not intended for that type of force in an way. User error caused that for sure.
    I would go with the metal plate, resin/epoxy glue and rivet repair as well.
    Hope the price you paid reflected the damage.
