Cracked bed...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ABregenzer, Feb 10, 2012.
  1. Feb 10, 2012 at 5:29 PM
    ABregenzer
    ABregenzer [OP] Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    So somehow the back portion of my bed has a pretty large crack in it… :mad:
    I'll post a picture up here sometime soon, but I was wondering if anyone had any ideas on how to fix this, preferably without spending too much money.
    Thanks!!
  2. Feb 10, 2012 at 5:31 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Depending on magnitude of the crack, some industrial strength adhesive & sealer should work to hold it together :cool:
    You're the first person I've heard of this happening to, you drop something super heavy on?
  3. Feb 10, 2012 at 5:33 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    sub'd for pics
  4. Feb 10, 2012 at 5:33 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    ive never heard of this...but i am worried about it a little. looking forward to seeing the pics.
    how i it happen?
  5. Feb 10, 2012 at 5:34 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    It's fiberglass, so why not some epoxy? Then touchup with some semigloss black.
  6. Feb 10, 2012 at 5:35 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Maybe contact Toyota about it? Couldn't hurt, unless it is from something you did and not normal wear and tear.
  7. Feb 10, 2012 at 5:36 PM
    theduck911
    Max
    Locked and Geared!
    The bed is not fiberglass, it's a composite plastic :cool:
    Unless, you're talking about fiberglass bedsides :notsure:
  8. Feb 10, 2012 at 5:37 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
    I bought it used. The guy I bought it from had a ladder rack right where the crack was so I didn't notice it until I brought her home. So I have no idea how it happened :confused:
    And it is in the actual bed itself, where the bed meets the cab.
  9. Feb 10, 2012 at 5:39 PM
    t4daddy
    North Alabama
    The sides and bottom are all one piece, are they not?
  10. Feb 10, 2012 at 5:40 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    How big is large? Wondering if it will just hold out if it's not too big or not too wide? Perhaps a professional spray on bedliner might help fill in the gap. That stuff bonds to the surface.
  11. Feb 10, 2012 at 5:41 PM
    Manwithoutaplan
    ID
  12. Feb 10, 2012 at 5:41 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Use a dremel and bevel the crack, drill the ends, fill with two part epoxy, let dry and sand flush.
    If you want some real good shit find a body shop with a 3M duramix gun and have them fill it with 08223 3M duramix adhesive
  13. Feb 10, 2012 at 5:43 PM
    theduck911
    Max
    Locked and Geared!
    Was just thinking the same thing^^^
    Damn us Max's are smart :cool:
  14. Feb 10, 2012 at 5:49 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    :cookiemonster: high five!
  15. Feb 10, 2012 at 5:50 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
    Basically that whole spot is cracked...
  16. Feb 10, 2012 at 5:51 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    3m Duramix FTW
  17. Feb 10, 2012 at 5:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
  18. Feb 10, 2012 at 5:54 PM
    theduck911
    Max
    Locked and Geared!
    Damn beat me too it :p
  19. Feb 10, 2012 at 5:55 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
    Where would I get some of that?
  20. Feb 10, 2012 at 5:57 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    05 has composite plastic bed, not steel=no bedliner.
    Max has the right idea. I would go a step further: Remove the bed, if you can't access the crack on the bottom of the bed. Bevel the bottom of the crack, use a heavy fiberglass mesh, and bed it into the epoxy on the bottom, cure, topcoat the mesh with more epoxy.
    Make sure that everywhere there is epoxy is roughed up, or the it won't stick. Use plastic weld epoxy and test it on a small, unseen spot. Check it for adhesion. A 1" strip of fiberglass mesh should be wide enough.
    If all you did was the top of the crack, it would flex and quickly break.
