cracked exhaust manifolds on 2009 4 litre
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattmctree, May 23, 2024.
  1. May 23, 2024 at 6:26 PM
    mattmctree
    mattmctree [OP] Well-Known Member
    2009 black tacoma trd
    hello,
    i recently discovered cracks on both left and right side exhaust manifolds. the cracks are right where the ports meet the flange. right side is cracked on one tube and the left side on 2. no check engine lights have appeared but i plugged my scanner in anyway and there are no codes either. i have heard the cracked manifolds can damaged the engine if left unrepaired ( not sure but have been told) so as a quick fix i scraped and sanded the 3 small cracks and used a high temp jb weld extremeheat paste to patch them up.
    i cant find any used manifold at wrecking yards and have called about a price on some aftermarket ones and they are 1300 each.
    i dont really have the cash to dole out so am trying to weigh my options . has anyone brazed theirs with success? i was also wondering if there are any other options such as omiting the catalytic converters and using a sensor simulator if that is even an option. i would like to keep the truck as stock as possible .
    the truck has 390 000 km however the clutch was done at 350 000 and all oxygen sensors have been replaced as well.
    any advice would be greatly appreciated.
    thanks
  2. May 23, 2024 at 8:27 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depending where they are cracked they may be able to be welded.
    Salvage yards can't legally sell used converters so you will not likely find a used one.
  3. May 24, 2024 at 6:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Can you upload some photos, please?
  4. May 24, 2024 at 10:44 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
  5. May 26, 2024 at 3:39 AM
    mattmctree
    thanks for the responses, i will try and load some pictures
    Torspd likes this.
  6. May 29, 2024 at 2:27 AM
    mattmctree
    i have found some used ones from a 2005 4 litre engine, im assuming they will fit just fine? one of the wrecking yards told me that the manifolds change in 2009 and were more prone to cracking is that true?
    i will upload pics at some point i just havent had time.
    thanks
  7. May 29, 2024 at 4:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The 05-08 will not flow as well as the 09-11 manifolds.
    Also, you risk a much older much more used catalytic converter.
    deanosaurus likes this.
  8. May 29, 2024 at 5:45 AM
    mattmctree
    Is there a reason they won't flow as well? Would it effect engine performance and cause the engine light to come on. I'm also wo seeing since the cats are good on mine If they could be put in place of the ones on the used manifolds if they were to fail. The manifolds I'm thinking of getting have 180 000 km on them. I looked into aftermarket aswell but alot are getting very poor reviews and don't last long.
    Other than the issue of less flow these manifolds should bolt right up to the existing engine correct?
    Did the exhaust change between the 2005 and 2009 models even though they are second gen trucks.
    Thank you?
  9. May 29, 2024 at 6:15 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    There was also a TSB on 2005s about exhaust manifolds making annoying ticking noise. I remember getting mine replaced many years ago. So 05 may well be slightly different from 09.
  10. May 29, 2024 at 6:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Better laminar flow from the design of the 09+. The 05 is a true log design.
    Steves104x4 likes this.
  11. May 29, 2024 at 7:01 AM
    mattmctree
    Oh ok. But it would still be a direct bolt in correct?
  12. May 29, 2024 at 8:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. May 30, 2024 at 2:43 AM
    mattmctree
    are there any good aftermarket manifolds that people suggest or even headers that i could have the catalytic section welded back onto?
    just trying to weigh all my options. good point about the different design and condition of the cats on the ones i sourced.
  14. May 30, 2024 at 6:37 AM
    mattmctree
    Ok I'll try and find the info in that thread. Thanks
  15. May 30, 2024 at 6:44 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Doug thorly makes some shorty headers you could weld the stock cats on
  16. May 30, 2024 at 6:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That link was meant for a different thread. Apologies.
