Cracked frame by where the motor mounts attach
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sierragrl, Jun 29, 2023.
  1. Jun 30, 2023 at 10:02 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, this is the first 3rd gen i've found with the issue. but it shows Toyota has a history with some failures in this area.
    shakerhood likes this.
  2. Jun 30, 2023 at 10:17 AM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I would open a case with Toyota. Even if they don't help you, it will be documented.
    MR E30, TacoSR523, whatstcp and 2 others like this.
  3. Jun 30, 2023 at 10:49 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  4. Jun 30, 2023 at 11:16 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    How big was the jump?
    Arries289, Rusty66, hiPSI and 7 others like this.
  5. Jun 30, 2023 at 11:22 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    This happened to my 06 after a jump, took to a frame shop and it cost $500. Maybe try getting a warranty through Toyota first though
    SR-71A likes this.
  6. Jun 30, 2023 at 11:29 AM
    oconnor
    oconnor Where am I?
    Midwest
    If it has truly been babied, we should be seeing a lot more of this. TW members are a vocal bunch when things go wrong.
    Vmax540, hiPSI, MR E30 and 2 others like this.
  7. Jun 30, 2023 at 11:35 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    That's a new one to me. The previous engine mount frame failures were on the frame rails themselves, but the middle-left in your pic clearly shows the reinforcement plate they attached to the frame to address that issue.
    I haven't before seen a failure close to the engine like that. The good news is that a proper fabricator can fix that, but you're looking at unbolting the engine and lifting it at least several inches to provide clearance for welding and whatnot. Engine removal might be necessary.
  8. Jun 30, 2023 at 12:45 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Those cracks are not frame cracks though, they are from the sheet metal that the radiator support is made of and I think is usually due to larger batteries putting too much weight on a part not designed for that weight.
    MR E30, SR-71A, cryptolime and 4 others like this.
  9. Jun 30, 2023 at 12:48 PM
    oconnor
    oconnor Where am I?
    Midwest
    And sheet metal cracks, especially at the radiator and cab mounts, has been a thing since the 1st gen.
  10. Jun 30, 2023 at 12:58 PM
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    I see what you did !
    df41590, t2c and Lawfarin[QUOTED] like this.
  11. Jun 30, 2023 at 1:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    Not his problem. His is more complicated.
    Correct.
    5nahalf[QUOTED], mjp2 and Chew like this.
  12. Jun 30, 2023 at 2:54 PM
    sierragrl
    sierragrl [OP] Member
    17 Tacoma
    Ok, so I'm gathering this is not exactly a frame crack. not sure if that's good or bad.
    At this point, I have made an appointment with Toyota....to get their take and see what they say.
    I hope they own this. I am not a 4Wheeler. I drive on dirt roads, but only to get to where I'm going, not just for fun. There's been no 'hard hit' that should have caused something like this.
    I had a previous Tacoma, an 05. Did the exact same driving with that truck. Sold it with 165,000 miles, never having to do anything to it other than basic maintenance.
    My fall back will be to find a good welder who has the capability to lift the engine up to get access to this.
    Hopefully I won't have to do that and Toyota will step up.
  13. Jun 30, 2023 at 6:00 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    MR E30 likes this.
  14. Jul 2, 2023 at 10:45 AM
    mjp2
    NJ
    whatstcp likes this.
  15. Jul 2, 2023 at 10:55 AM
    #35
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    It replaces the whole engine mount along with frame reinforcements. So unless the block is cracked or broken.
    MR E30 and mjp2[QUOTED] like this.
  16. Jul 2, 2023 at 11:18 AM
    #36
    amalik
    amalik Well-Known Member
    Denver
    Is it not possible to JB Weld it or something?
  17. Jul 2, 2023 at 11:30 AM
    #37
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    wouldn't the second dropdown 'replacement 3.5l frame perch plates' item menu be an option here?
  18. Jul 2, 2023 at 1:49 PM
    #38
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Oh boy…
    wayupnort, jmneill, jjsinaz and 6 others like this.
  19. Jul 2, 2023 at 2:48 PM
    #39
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    I cant even see it. My eyes must be getting old.
    Toy4me likes this.
  20. Jul 3, 2023 at 7:49 AM
    #40
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    and not nearly as big of deal as the frame itself cracking
    TacoSR523 likes this.
