Cracked Headlights... from hids??
Discussion in 'Lighting' started by gouge44, Dec 3, 2011.
  1. Dec 8, 2011 at 10:46 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
  2. Dec 8, 2011 at 10:53 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I have 8k's...and that's the very top limit my teenage naivete will let me go.
    Blue enough to say "haha, I'm silly. Look at how blue that is" but white enough to say "I can see!"
  3. Dec 8, 2011 at 10:57 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    What about 3k for the headlights any one have pics of that I like the blue but yellow is more functional for fog and rain and dust.
    Thanks for the help I'm kinda being annoying with this but I'm just looking around before I buy it
  4. Dec 8, 2011 at 11:25 PM
    BAMFTACO
    Juan
    Kings bruh
    Haha its all good Man but it makes a cool whistling noise you jelly
  5. Dec 8, 2011 at 11:34 PM
    BAMFTACO
    Juan
    Kings bruh
    Hahaha that's funny shit
  6. Dec 9, 2011 at 11:17 AM
    Shemicals
    Build Page
    the projector lens is purple... not clear...
  7. Dec 9, 2011 at 11:31 AM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    the derp runs deep in here.
  8. Dec 9, 2011 at 12:11 PM
    Aw9d
    Aw9d That one guy
    12k is purple.. It's neat looking but doesn't do much other than get you pulled over a lot.
    I have 5k in my moms 05 and my dads 08, both were installed when they got the trucks band new in those years. So never had any issues in all these years other than one bulb going out.
  9. Dec 9, 2011 at 2:18 PM
    Shemicals
    Build Page
    never been pulled over for my lights
  10. Dec 9, 2011 at 2:23 PM
    Aw9d
    Aw9d That one guy
    Call yourself lucky. I had 12k in my integra and was getting pulled over left and right for them. Here in Az they care about the color only. If it puts any color other what white on a piece of paper 12inches away, ticket. (Yellow seems to be ok here, my motorcycle has 1 yellow/1 white HID, never been ticked for it)
    Put 5k's in, never been pulled over since. Both my parents have 5k's never been pulled over.
  11. Dec 9, 2011 at 10:43 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    12k:eek:
    first off your factory fogs will put down more light than this setup second it will be purple :rolleyes: third if your buying 12 anything it's got to be some piece of shit pnp kit.
    dude save your money retrofit it's a thousand times better or the alternative is to run a high performance halogen bulb.
    check this link to clearcorners.com there is a solid write up on halogens and the choices you have for bulbs. also look inot there hid faq page as it will basically repeat what i just told you about choosing a color temp. if you want hids look into 4300k or 5k no higher or you will lose light. in a quality setup the color of the lights can be dramatic not from the bulb temp but, the color flicker from the projector ie, the cut off line.
    http://www.clearcorners.com/tech/001/
    http://www.clearcorners.com/tech/005/
    or go to theretrofitsource.com and buy your self a real set-up parts will run around 300 dollars for a very respectable setup one that will in fact be brighter than any oem hid light by a good bit. plus your not going to glare other drivers into a ditch on the side of the road :)
  12. Dec 9, 2011 at 11:00 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    to the op i have seen some aftermarket housings do this in around a years time but, i'm referring to micro hairline cracks that are barely noticeable. they are more cosmetic than anything else but, i guess given enough heat and time they would manifest into actual cracks.
    for the stock housings to crack i would have to believe its from the heat being blasted at the lens. the plastics used in the oem headlight are of a much higher quality than the after market housings there seems to be a misconception of the temp that xenon bulbs operate at. while they draw less power once they are past the initial ignition the temp is actually much hotter than a halogen bulb.
    a 55 watt xenon for example can get so hot it can melt the rear of the housing if not retrofitted properly. a 35 watt system on average will still generate more than likely one and a half to two times the amount of heat the halogen bulb will.
    so in this situation more heat means less power drain this is usually the opposite in most situations.
  13. Dec 18, 2011 at 8:48 PM
    jacobblocker
    jacobblocker Well-Known Member
    Jacob
    east tennessee
    billet grill, black out emblems, procomp 7089, hankook dynapro 265/70/17
    i want a blue look to my headlights and maybe even purple but i still want good lights and i have just the stock headlights on an 11
  14. Dec 18, 2011 at 8:55 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    if you think the 12k is bright :rolleyes: try switching to a 4300 or 5k you may just shit your self lol.
    i'm actually confused here a little bit there are guy's providing good info about lighting on tw how is it we still have guy's switching to xenon lighting systems and running bulbs that are so high on the kelvin scale?
    10k ah to hell with it lol
  15. Dec 18, 2011 at 9:05 PM
    #35
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    you literally cannot have good lighting with bulbs that high on the kelvin scale :confused:
    4300 or 5k thats all. i would even venture to say that a quality 5k bulb would provide twice the visible light of a 12k possibly more. this is not an opinion its a fact. i don't mean to come off as a know it all or a smart ass here i'm just informing.
    and the color flicker of a projector goes a loong way to making the lights appear blue to other drivers the projector lens themselves will look blue/ purple. they will also light street signs purple then blue then bright white as you draw nearer to them. its actually quite pretty when done right and extremely effective.
    this also has to do with projector choice for instance the mini d2s has almost no color flicker or color in the cutoff what so ever while the fx-r has a ton! the most of any projector i have seen minus some of the hybrids and heavily modded ones out there if thats all your after but, you want nice lights go that route.
    i would not lie to you i know this for a fact bud :)
    edit: i'll just leave this here...
    click and learn :)
  16. Dec 26, 2011 at 7:02 PM
    #36
    jacobblocker
    Jacob
    east tennessee
    so what do i have to buy to get the good projectors ?
