Cracked manifold = running crappy?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, May 29, 2019.
  1. May 29, 2019 at 10:42 AM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Please tell me that the visible crack on my exhaust manifold could be drawing in enough air for this thing to run crappy. I just noticed it after replacing front pipe and O2 sensor. Please please please...
  2. May 29, 2019 at 11:15 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I bet it's sounds crappy anyway.
    Luv my yota likes this.
  3. May 29, 2019 at 11:17 AM
    eon_blue
    Azusa, CA
    I bet it could...is it throwing a code too, P0420?
  4. May 29, 2019 at 11:23 AM
    Rachelsdaddy
    Southern NH
    No codes. Just running crappy. Originally I thought it was running lean but it’s actually running rich. The O2 is reading all types of crazy along w/ the fuel trims. I’m assuming this is my problem. Cracked all to crap. Replacing it in an hour
  5. May 29, 2019 at 11:24 AM
    Rachelsdaddy
    Southern NH
    Not as crappy as it runs. :hattip:
  6. May 29, 2019 at 11:36 AM
    eon_blue
    Azusa, CA
    Surprised it doesn't throw a code, I would think the O2 sensors are reading odd data likely due to the crack. It should run better after you replace it.
  7. May 29, 2019 at 11:40 AM
    Rachelsdaddy
    Southern NH
    I hope like Hell so...
  8. May 29, 2019 at 12:44 PM
    Emmetjmcc4
    Emmetjmcc4 Well-Known Member
    Emmet
    Michigan
    2002 Tacoma 4x4 270k, 1995 Tacoma 4x4 353k RIP
    American Racing 15x8 -19 off. Cooper Discoverer stt pro 31x10.5r15 Allpro baja tube bumper Fox racing 2.0 all around
    My manifold was cracked bad and it felt like I had to put the pedal to the floor in any gear to go anywhere
  9. May 29, 2019 at 5:44 PM
    Rachelsdaddy
    Southern NH
    Weeeeeee, it does run better! I’m kinda paranoid about the Bosch O2 sensor. They swear it’s the right one but it seems too short, doesn’t reach into the exhaust stream like the Denso did.... thanks
  10. May 29, 2019 at 5:52 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You really can't trust 'them' or 'they' or their opinion as they don't love our tacos like we do. Trust the collective here on the forum. Many guys on here with decades of detailed experience with Toyota trucks and 4x4s.
    A shop that swore to me that a Bosch A/F sensor is correct on my Yota wouldn't be getting anymore business from me.... If I used shops:D I would put the correct Denso sensor in, but that's me
  11. May 29, 2019 at 6:00 PM
    eon_blue
    Azusa, CA
    I would swap it out for a Denso, Toyotas don't have good history with working well with other brand sensors
  12. May 29, 2019 at 6:04 PM
    Glamisman
    Glamisman Well-Known Member
    if you check the "pending" portion of the scan tool Ill bet that that code is ready to pop on the CEL... it hasnt meat all of the parameters to set the code yet.
    Rachelsdaddy[OP] likes this.
  13. May 29, 2019 at 6:11 PM
    Rachelsdaddy
    Southern NH
    For the archives... good riddance
    eon_blue and cruiserguy like this.
  14. May 29, 2019 at 6:16 PM
    cruiserguy
    Elijah
    SEKS
    Damn, the manifolds on the 2UZ-FE on the 100 series Cruiser were known to develop a hairline crack and then that annoying tap when cold until it closed off when heated.
    I don't know that they affected performance much though? (long time, don't remember though)
    So you thinking that split could've been affecting that much? I guess it's definitely plausible
  15. May 29, 2019 at 7:23 PM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    Whether cracked manifold or faulty sensor, best to have them both replaced at the same time. Might want to go ahead and clean the injectors while at it.
  16. May 30, 2019 at 5:08 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    My 95 2.7L was cracked all the way around when I replaced it. Honestly though, as far as I could tell, it was not affecting the performance. I could hear it leaking, but didn't notice any change after replacing it.
    I went with a cheap Rock Auto replacement, so maybe next time it cracks... :rimshot:, I'll see a difference.
    cruiserguy and Breakfast Taco like this.
  17. May 30, 2019 at 7:43 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I'm paranoid to all get out with those cracks! I've had two pre '00 3rz with the cast manifold now, and both developed cracks in the cyl head.
    I strongly recommend getting a leak down test done on each cylinder!
  18. May 31, 2019 at 9:11 AM
    rustytoys
    rustytoys Active Member
    USA
    1999 Toyota Prerunner
    So are you saying you think the cast manifold contributed to the head cracking? Just curious, got a 3RZ too.
  19. May 31, 2019 at 9:45 AM
    Abeyancer
    Jimmie
    PNW
    In my very limited experience? Yes I do whole heartedly believe that. On both my motors the cyl directly in line with the crack on the manifold turned out to be cracked, and both were cracked in between the 2 exhaust valves
  20. May 31, 2019 at 9:50 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    extra oxygen in the exhaust port makes it run much hotter locally.
    Abeyancer likes this.
