Cracked manual transmission?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by b arnold, Apr 1, 2022.
  1. Apr 2, 2022 at 7:45 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Only use 6 point metric sockets, otherwise this will happen.
    willie2 and b arnold[OP] like this.
  2. Apr 2, 2022 at 7:57 AM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Those are just veins, near the nuts. Pretty normal. you should be ok. :thumbsup:
    b arnold[OP] likes this.
  3. Apr 2, 2022 at 8:13 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    I am sure you know, but just in case, replace the plug.
  4. Apr 2, 2022 at 8:18 AM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    The surface cracks are from the casting process. When the molten aluminum hits the cooler surface of the mold, it flashs to a solid quickly, leaving these small surface cracks behind. Nothing to worry about, all for looks. Nothing structural, if it was, it would be leaking.
    And I second everyone's 6 point socket usage! And maybe just a touch of heat to expand the aluminum around the bolt.
    33yrsoftoys and b arnold[OP] like this.
  5. Apr 2, 2022 at 8:57 AM
    b arnold
    b arnold [OP] Member
    Texas
    2020 TRD Sport V6 Manual
    yes, just got back from the dealer and ordered a new plug for when I get my extractor sockets in the mail.
  6. Apr 2, 2022 at 9:02 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Duct tape should fix it ..just don't go past 100mile an hour
  7. Apr 2, 2022 at 9:45 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I'm sure they're all pressure tested for leaks before they leave the factory.
  8. Apr 2, 2022 at 11:06 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yep, i start worrying when you hear loud screaming noises when going through the gears. I was at a traffic light making a turn when a 3rd gen manual tacoma coming from the opposite direction passed in front of me. Something was very wrong with that truck with the noise it made while shifting through the gears.
  9. Apr 2, 2022 at 11:31 AM
    b arnold
    Texas
    Yea I’ve had no issues, nothing grinding or leaking. I’d assume if it was really cracked it would leak and if you didn’t know you’d run out of gear oil and definitely know something is wrong.
  10. Apr 2, 2022 at 12:03 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Those are spider cracks from the sand casting process. They should be external to the cast itself (sand side). If you ever worry about an aluminum casting, file a bit away and see if the crack extends below. If it does, you’ll need a weld repair. Cylinder head/ block machine shops are the best at this repair (experience). This is very common, as is flashing…
