Cracked mud flaps - anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarkSlayer, Mar 25, 2011.
  1. Mar 25, 2011 at 7:59 AM
    BarkSlayer
    BarkSlayer [OP] Well-Known Member
    Jim
    Northwest Ohio
    Silver SR5 with 2.7 liter 5-speed stick
    Bed-Buddy motorcycle tie-down bar installed in headwall.
    Has anyone else experienced cracked front mudflaps? My '07 4WD has 65K miles and both front mudflaps are cracked. At highway speeds, especially in a stiff crosswind, they make a thumping noise that's rather annoying. Then I find out that new ones are $94 each! The crack isn't visible, but if you examine things closely, you can plainly see where the plastic has given way. Is there a better option than OE?
  2. Mar 25, 2011 at 8:01 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Amarillo, TX
    OME Lift
    Super glue?!!
  3. Mar 25, 2011 at 8:01 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Yep. Back when I had them on, (Had to remove them to fit 285's) Mine did that. I trimmed about 3-4 inches off the bottom of them and they stopped flapping around. Those things are so big they are a sail in the wind.
  4. Mar 25, 2011 at 8:05 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    yep. take em off
  5. Mar 25, 2011 at 8:09 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | Access Roll-up Tonneau Cover, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat ---------------------------- | INTERIOR | Flyzeye V2W (Amber/White/Amber) Audio: Alpine CDA-117, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    Yep, exactly what happened to my left front flap. Looked fine until I flexed it and then the crack was revealed. It started about an inch in length then kept expanding until it almost completely separated. And yeah, dealer & ebay costs are rediculous. I went back with stock ones I bought off a TW member that posted them up for sale... I knew fitment would be right whereas I wasn't so sure with aftermarket ones. Keep checking the 2nd gen BST thread.
  6. Mar 25, 2011 at 9:15 AM
    wvataco
    wvataco Member
    Bryan
    West Virginia
    2010 dbl cab trd sport
    I took the factory ones off my truck before it left the lot. If you want them I would take 150.00 for all 4.
  7. Mar 25, 2011 at 10:33 AM
    BigT
    BigT Active Member
    Pa.
    16 trd off road
    Does anyone know if oem flaps from a 4x2 will fit an 05 4x4?
  8. Mar 25, 2011 at 11:33 AM
    macgyver
    Brad
    Canton, GA
    All the second gen flaps should be the same.
  9. Mar 25, 2011 at 12:20 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 Access Cab 4x4, 17 TRD Sport 6 MT
    Leer 100R
    You might want to take yours off before they break and mess up the paint on your door... I didn't, and had to spend some time buffing out the marks/scratches.
  10. Mar 25, 2011 at 12:27 PM
    GirlTaco
    GirlTaco Member
    Brandy
    Alabama
    07 SR5 TRD Off-Road 4x4
    One of mine broke the first time I took it off road. They are too long!
  11. Mar 25, 2011 at 12:56 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Just keep an eye on the TW for sale section. Many folks remove them and sell them for varying prices.
  12. Apr 1, 2011 at 3:57 PM
    coolreed
    coolreed Well-Known Member
    OKC
    06 PreRunner TRD Off Road
    20's, Chrome Grill,Handles,Mirrors. Sat Radio, Dynomax Exhaust K&N Air Filter, Bilstein 5100's, Cross Drilled Slotted Rotors
    I just discovered my drivers side front mud flap has cracked on my 2006 Pre Runner.
    Can you purchase one from Toyota or do you have to buy the whole set? Also, does anyone know the PN of the Flaps and those Plastic Keepers that hold the Mud Flap on?
    Thanks!
