cracked my bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by riftsawn, Jan 19, 2015.
  1. Jan 19, 2015 at 12:09 PM
    riftsawn
    riftsawn [OP] Active Member
    Colorado
    08 double cab
    I had some 10' 2x4s in the back of my truck that I bumped with my tractor when plowing... Damn thing slowly slid into the ends of the wood. It broke a 6 in or so flap in the front of my bed. Can the composite bed be fixed? I have done fiberglass work before but not sure what it anything will bond to the composite bed? I sure as heck am not going to replace the whole bed. Thx!
  2. Jan 19, 2015 at 12:21 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  3. Jan 19, 2015 at 12:37 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Try JB weld. It would be my best guess. You can find it at any hardware store.
  4. Jan 19, 2015 at 1:40 PM
    htgreen3
    htgreen3 Well-Known Member
    Central Virginia
    2015 TRD OR
    Get some aluminum diamond plate and make a panel to cover the whole front plastic panel and bolt it to the existing plastic bed, butting some silicone over the broken seams to waterproof the bed.
  5. Jan 19, 2015 at 1:41 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Pics or didn't happen!
  6. Jan 19, 2015 at 1:46 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I've wondered how much force it would take to crack one of these beds; apparently it takes a bit. I fixed a break on my wifes Subaru under the front license plate with PC-7. Pretty strong two part glue make for all kinds of plastics and composites.
  7. Jan 19, 2015 at 1:59 PM
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    Good question. My guess is that anything with a tractor would be too much force for the TACO's composite bed to handle.
  8. Jan 19, 2015 at 4:19 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Now this I'd like to see. I can't see it happening unless it was really cold or something very pointy.
  9. Jan 19, 2015 at 4:26 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    You can't see a 2x4 with several thousand pounds of force, and possibly more than that, going through a composite bed? I've seen a thousand pound load go through the back of a truck cab and the front of the box at 30 kph (20 mph). Boxes aren't THAT strong.
  10. Jan 19, 2015 at 4:29 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's just polyester resin fiberglass.
    If you've done glass repair, you know the drill: grind, sand, tack cloth, resin, cloth, squeegee, dry, repeat as desired.
    Wiggins likes this.
  11. Jan 19, 2015 at 4:38 PM
    LegitGreenTaco
    LegitGreenTaco Photosynthesis.
    2002 Regular cab base A/C fixed now.
    Westin lights, Westin Light bar holder, New front bumper, Custom floor matts, Steering wheel cover, board in bed to keep groceries from rolling around, new radio, New flat bed cover.
    I would just take the plastic stuff out and if wanted put some new stuff in can't be hard
  12. Jan 19, 2015 at 4:52 PM
    devkurf
    devkurf Member at Large
    midwest
    What were you plowing in January?
    I definitely wouldn't use JB weld.
    If its just a small 6 inch flap I would try to line the flap back like it was, use some thing to hold it together and in place, and use some PL construction adhesive, then paint it black. Just dont let it dry anywhere you dont want it forever. It will dry stronger than the composite bed. They have it at Home Depot.
    Edit: I"m not sure how it takes to paint, never tried it.
  13. Jan 20, 2015 at 8:31 AM
    riftsawn
    Colorado
    08 double cab
    Attached is the pic as requested... I put some black silicone in the crack to keep it from leaking water into the bed until I can fix it. To answer some of the other questions yes it was cold around 10- 15 degrees but that's not bad not in this country anyway. I bumped into it very slowly, maybe 1/2 a mile an hour while the blade was down pulling 20" of snow. I have a JD 1050 which is a mid size tractor... that I would guess weighs apx. 2500 lbs.
  14. Jan 20, 2015 at 8:49 AM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    He used a GPlus URL, here ya go....Nasty
  15. Jan 20, 2015 at 8:55 AM
    Shelf Life
    Rob
    Central Oregon
    Ouch. Looks fixable though. I don't want to know what Toyota would charge for a new bed.
  16. Jan 20, 2015 at 8:59 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    I think if it was a steel bed it probably would have pushed the front part of the bed right into the cab.
  17. Jan 20, 2015 at 9:03 AM
    choppersx
    choppersx ZoMbiE aLeRt
    Frank
    SoCal
    1968 Ford Mustang
    Lifted Bilstein shocks 5100's Front set 1.75, Rear set 1.5 ICON 3 Leaf Progressive add on / Lights-Retrofit with Halos & interior Dome / Tinted windows/AFE PRo Dry Air Filter / Go Rhino Bars / Flowmaster Exhaust 50 series
    Looks deep, you might need another box. if you plow into a tractor looks you where going more than 1/2 mph.
    Sucks man.
  18. Jan 20, 2015 at 9:10 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Search Craigslist for "Tacoma Bedliner"
    I've seen beds on there for cheap because people don't realize it's the actual bed and not a bed liner.
  19. Jan 20, 2015 at 9:23 AM
    fizik
    fizik Accidental Offroader
    Minnesota
    '13 DCSB SR5, '10 DCSB TRD OffRoad (deceased)
    His driveway, maybe? :D
  20. Jan 20, 2015 at 9:30 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    She was heavy enough to crack the bed, apparently. :eek:
    _____________________
    In case you were wondering, a replacement bed bought new is about $1300 at VillageToyotaParts, though I suspect shipping will add a lot to the total, since it probably needs pallet freight.
    DoorDing likes this.
