cracked my bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by riftsawn, Jan 19, 2015.
  1. Jan 20, 2015 at 9:31 AM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    He was actually plowing devkurf's mom.
  2. Jan 20, 2015 at 9:36 AM
    riftsawn
    riftsawn [OP] Active Member
    Colorado
    08 double cab
    I didn't realize there was a recall on the Tacoma beds, I thought that was only for the Tundra's? Luckily the impact never touched the cab, so there is no damage whatsoever there, which surprised me because there is mayb2 2" of clearance between the 2. All it did to the tractor was punch a hole in the wire mesh grill, again lucky for me it didn't get the radiator or even the debris screen directly behind the grill!
  3. Jan 20, 2015 at 9:39 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  4. Jan 20, 2015 at 9:56 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    DoorDing likes this.
  5. Jan 20, 2015 at 10:11 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    If you do attempt to repair or otherwise keep it, drill some holes at each end of the crack to stop it from spreading.
  6. Jan 20, 2015 at 10:14 AM
    OZ-T
    Peter North
    British Columbia
    They generally don't use rebar in curbs
  7. Jan 20, 2015 at 10:41 AM
    Mapcinq
    Ontario, Canada
    They do here.
  8. Jan 20, 2015 at 10:48 AM
    xsteinbachx
    xsteinbachx Well-Known Member
    Victoria, BC
    2017 White TRD Sport DCLB 4x4
    Only at driveways for reinforcement.
    BC - Civil Tech.
  9. Jan 20, 2015 at 10:58 AM
    Blze001
    Blze001 Breaks things.
    Virginia
    2013 TRD Sport DCSB
    :rofl:
  10. Jan 20, 2015 at 11:00 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    As I see it you have two real choices and a poor stepchild of a third choice:
    1. DIY fiberglass repair, which I mentioned above and which you say you've done in the past. Properly done, this will be hella strong and won't have any stength issues, but will leave a big cosmetic blemish.
    2. Follow through with replacing the entire bed. If I was taking that path - I'd probably get the insurance company involved as it'll run to well over 2000 bucks between parts and labor.
    3. You could try and get a boatyard to do the repair for you since they're expert at glass repair. They could repair the glass and match the texture so you'd never see it. But boatyards are notorious for working on their own schedule and you might be without your truck for a month or more while waiting for them to perform the repair. And I'm not convinced you'd save any coin at all vs. option 2.
  11. Jan 20, 2015 at 11:18 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    i had a crack in the front corner of my bed when i bought it. i did the fiberglass matting/resin fix and then got some raptorliner and did the whole bed (and also my rockers and flares) to cover up the ugly tan piece in my bed. but the glass eventually let go. i assume its because it was in the corner and couldnt handle the flexing for the 2 sides. i would think since this is the middle of one piece if should hold just fine. this pic was about a week after application [​IMG]
    this is just over a year later
    it actually has stayed on the composite a little better than the metal on the top rail of the bed (i took the plastic caps out and sprayed those too)
  12. Jan 20, 2015 at 11:32 AM
    Ran s Taco Stand
    Ran s Taco Stand Member
    Randy
    Kings Ferry, FL
    06 Prerunner SR5
    '06 Prerunner 2wd Access Cab 190099 miles and counting!! Stock, but still Bad-Ass!! '95 Tacoma 5speed 2wd 348,000 miles '98 4Runner SR5 Auto 2wd 329,000 miles '88 4Runner SR5 Auto 4wd 2??,??? miles on blocks for now
    My gang box cracked my bed after impact with another vehicle (less than 40mph) visiting CA from N. E. Florida for work... I wanted to see the Pacific Ocean so I went to Long Beach, that's when a crazy CA driver pulled out of a side street (almost T-bone me) then got in front of me while approaching a cross walk that had a green traffic light. Meanwhile, I was thinking this guy is just slowing down...when he locked down his brakes for some pedestrians still on the sidewalk! Of course I slammed into him! I wondered why it felt like a double impact. I didn't notice the damage until almost a month later...not much can be done to repair it in my opinion. I replaced the front bumper, hardware and all... free parts off the "pay it forward" forum during my California adventure!
  13. Jan 20, 2015 at 12:50 PM
    Mapcinq
    Ontario, Canada
    I used to work with my dad, whos a civil engineer... I swear I saw rebar in all the curbs they were about to pour. Maybe because the driveways were so close? Hmm... now Ill have to ask.
  14. Jan 20, 2015 at 1:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Use your insurance. That is why you have it. Homeowners may even cover it, if not file it on your auto policy,
  15. Jan 20, 2015 at 2:43 PM
    #35
    xsteinbachx
    Victoria, BC
    Could be an Ontario / Municipality thing too. Some are much crazier than others.
  16. Jan 20, 2015 at 5:27 PM
    #36
    spp
    spp OC, Kalifornia
    OC California
    Looks like an asphalt curb to me from that picture.
  17. Feb 20, 2015 at 4:29 AM
    #37
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
  18. Oct 10, 2015 at 8:19 AM
    #38
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    I'm just going to bump this
    I recently had a transmission slide in my bed after it some how undid it's strap and put a small crack in the front of my bed while driving. I read about some fiber glass, maybe some stuff with some horse hair or whatever will help. I really like the idea of making up a nice metal plate to rivet or bolt to the front part of the bed. I'll let you guys know what I end up doing.
  19. Oct 10, 2015 at 9:25 AM
    #39
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
  20. Oct 10, 2015 at 9:28 AM
    #40
    Doublecross
    Robbie
    New york
    Work in progress
    i've welded composite material before. basically it looks like a soldering gun with a different tip and get hotter. you place steel screen material on it and melt it into the composite material to reinforce it than if you have any composite material laying around you melt that
    onto the top to smooth it out.
