Cracked sheet metal above radiator body bushings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upTOPOverland_Drew, Nov 3, 2019.
  1. Nov 3, 2019 at 11:24 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    :rofl:
    I think I just pissed myself
  2. Nov 3, 2019 at 11:26 AM
    tcjacado
    tcjacado Well-Known Member
    scottalot likes this.
  3. Nov 3, 2019 at 11:29 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    The frame is a wet noddle on these trucks so adding poly bushing likely won't do much. Add heavy front bumper, winch and the oscillations become more pronounced.
  4. Nov 3, 2019 at 11:31 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Makes me scared to hit a pothole .
    tcjacado and CusterFan like this.
  5. Nov 3, 2019 at 11:32 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  6. Nov 3, 2019 at 11:34 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Nov 3, 2019 at 11:36 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Okay. Because clearly I don't know what I'm doing here.
    Take apart your OE radiator core support mounts and see what I am talking about if you don't believe me.
  8. Nov 3, 2019 at 11:41 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Ease over the railroad tracks for sure. We have some rough ones around here.
    Bleep100[QUOTED] likes this.
  9. Nov 3, 2019 at 11:42 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    He did say a stock truck was having the issue...... I'd at least think that person would bring it in....
    Boss hoss, SandyTaco4x4 and tcjacado like this.
  10. Nov 3, 2019 at 11:44 AM
    Syncros
    Syncros Well-Known Member
    Early FJ cruisers have sheet metal issues ahead of the firewall too.
    shakerhood, MikeyD.25 and 12TRDTacoma like this.
  11. Nov 3, 2019 at 11:44 AM
    Itchyfeet
    Have no reason too, but anyone thinking poly bushings will be the be all end all to this problem is likely an engineer a Boeing these days. If one starting adding 200+ pounds of weight to the front frame horns is it's only going to make the core support move with the frame rails more. Adding poly bushing will not stop the metal fatigue.
    Rick111, Boss hoss and GreyBaldTaco like this.
  12. Nov 3, 2019 at 11:48 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm trying to figure out how adding stiffer, less compliant bushings will improve the situation. If anything it seems to me like they would force the core support to flex with the frame more.
    CREM_808, Rick111, specter208 and 2 others like this.
  13. Nov 3, 2019 at 11:49 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I had some cracking on mine, though nowhere near as bad as yours. I have poly bushings up front, in case anyone cares.
    My solution was to completely cut out the trouble area and weld in some 14 gauge. Has held up well for quite some time now.
    08C694DA-9441-49BE-8183-6D4A74D0D0EF.jpg A2F6B0E9-51F6-4368-9E63-5C0A3F6D07D8.jpg
    Dryvah, Deeahgee, nartmot and 7 others like this.
  14. Nov 3, 2019 at 11:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You clearly don't understand what I'm getting at here. Even when tight, the factory bushings allow a ton of movement. When worn out (which happens at mileage as little as 15-20K) they allow even more slop which not only damages the core support metal mounting points by making it oblong (as well as the frame mounting points), but it allows the support to dance around a ton, particularly where the battery is located due to the heavy weight of that thing. Toyota just uses shit rubber on the bushings for this truck because of they are attempting to make this thing as compliant as a Camry. Because it bounces around all day in there for those who wheel even a little hard their support will eventually collapse, buckle and crumple up in the exact spots the OP is posting about.
    It doesn't solve any issues on its own, other than preventing bouncing around, which is a big deal alone, but doing those coupled with a battery relocation nets you years more worth of service life on an already collapsed/ damaged/ crumpled up core support for those who use their wheeler as a daily driver. On a new or undamaged setup it prevents issues down the line.
    This is nothing new and you definitely don't have to work as an engineer at Boeing to understand what is happening here. You secure the slop and play and minimize weight bearing on an already weak setup. It's first grade stuff actually.
    This topic has been covered ad nauseum at this point. You don't have to pull apart your garbage OE bushings because I have done the work for you nearly 5 years ago. Check the link below if you don't believe me.
    https://www.tacomaworld.com/threads...-support-mounts-cab-also.361346/#post-9806898
  15. Nov 3, 2019 at 12:15 PM
    #35
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I checked mine. No cracks, but still have stock front fascia and bumper. Driven 1000kms of washboard. Mostly try not to hammer the truck, but sometimes it’s unavoidable.
    I’m fitting a winch bumper next month. We’ll see what happens.
  16. Nov 3, 2019 at 12:33 PM
    #36
    Itchyfeet
    It's not going to stop the frame horns from being a wet noddle. The frame horns on my F150 are easily 2-3 if not 4 times bigger in size. I guess it's the price to pay if you want a good crash test
  17. Nov 3, 2019 at 12:40 PM
    #37
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Agreed all around there. The radiator supports on these trucks are just built out of soda can metal. It makes sense for crash testing but it also sacrafices reliability for us. All we can really do is work with what we got or re- engineer the design from the rear of the front end of the cab on forward, and eliminate all of the trash metal all around by building an engine cage. It is costly and time consuming, however, and for those of us who DD their truck it's a mod which is not too feasible unless you get yourself a rental for a good 2 or 3 months.
  18. Nov 3, 2019 at 1:12 PM
    #38
    Itchyfeet
    Maybe the answer is to buy another core support and make a doubler for certain sections to extend the life. It's kind of shitty that this is happening
  19. Nov 3, 2019 at 1:19 PM
    #39
    upTOPOverland_Drew
    upTOPOverland_Drew [OP] upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    def a bummer
    CusterFan[QUOTED] likes this.
  20. Nov 3, 2019 at 1:20 PM
    #40
    upTOPOverland_Drew
    Drew
    Littleton, CO
    already have energy bushings. But how do you stop this problem?
