Cracked Uniball - Both of them?!?!?
Discussion in 'Suspension' started by Blkturbo!, Jul 2, 2011.
  1. Jul 2, 2011 at 12:58 PM
    Blkturbo!
    Blkturbo! [OP] Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    BOTH (left and right side) of my uniballs are cracked and missing small chunk of material along the bottom side of the ball joint in my Downsouth Motorsporst UCAs!! Only a few hundred or more miles and street driven ONLY so far. Both are damaged identically. W-T-F is the issue here????
  2. Jul 2, 2011 at 1:04 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Thats just the mis-alignment spacer. I have done that to mine before also. It happened to mine when I was in a rush and tightened things back up with the arms at full drop. I didnt make that mistake twice, those little spacers are pricey.
  3. Jul 2, 2011 at 1:27 PM
    Blkturbo!
    Sean
    Henderson, NV
    Can it be driven like this untill i get back to my mechanic to replace them? Is this my mechanic's fault for what looks like is the snap ring that cracked it? I wonder if it happened like how yours broke, or if mine broke from this snap ring while driving?
  4. Jul 2, 2011 at 1:30 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    I thought that's what happens when a spacer lift is used?
  5. Jul 2, 2011 at 1:33 PM
    Dark Knight
    Jeff
    NC/SC
    I drove mine for a while but its hard to tell the extent of damage on yours. What happened to me was that the arms were at full drop and with the bolt loose the alignment spacer fell out of the uni-ball. As you tighten things up the edge of the mis-alignment spacer that meets the uni-ball (where yours are broken off) catches on the C-clip and as you tighten down it breaks off that side of the spacer.
    To avoid this I lacked up the lower control arm so the spindle would meet the upper control arm in a more horizontal position and tighten to spec.
  6. Jul 2, 2011 at 1:35 PM
    Dark Knight
    Jeff
    NC/SC
    ohh to add, the line that goes all the way around in not the issue here. The broken part is what looks jagged.
  7. Jul 5, 2011 at 4:33 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    X2. I did a similar thing with my All-Pro UCAs, except the lip of the spacer bent instead of breaking off. (It's possible All-Pro doesn't heat treat the spacer as hard as DSM did, which would have made the steel more brittle.)
    To Blkturbo: In addition to a new spacer, order a new bolt and nut from DSM as well. Because the spacer wasn't seated properly when torqued down, the bolt may have been bent, eaten into the spacer bore, etc.
