Cracked Windshield
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gruber1922, Oct 11, 2019.
  1. Oct 11, 2019 at 6:20 AM
    Gruber1922
    Gruber1922 [OP] Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    For those who have had their windshield replaced; where would you recommend? Rock cracked my windshield a few weeks ago in the desert. It’s non repairable. I’ve heard horror stories with windshields leaking after replacement
  2. Oct 11, 2019 at 7:10 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Where I’m at there is a very good family run glass company that does great work. I have them replace two windshields no leaks ever. So I think it’s more about finding a good reputable installer. Imo the mom and pop small business owners tend to take more pride in their work as it is their livelihood.
    outxider and Muddinfun like this.
  3. Oct 11, 2019 at 7:13 AM
    Bodyguard89
    Bodyguard89 Well-Known Member
    Montana
    2010 TRD OR DCSB
    Still in planning phase ...
    SafeLite Auto Glass was who I went to with my last vehicle. Can schedule appointment online and they will help locate nearest one to you. You can then either go to them or they come to you. No complaints with their work. No leaks that I could tell. Just follow their guidelines including no washing for at least 24 hours after replacement.
  4. Oct 11, 2019 at 7:17 AM
    gotoman1969
    When I found the company I used it was because safelight imo over charges. They wanted like 500 for the front windshield installed, the company i used came to my house with the brand windshield I wanted $220 installed.
  5. Oct 11, 2019 at 7:35 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    just tell your installer to install like he cares......
    Mom & Pop are the best ........
    outxider likes this.
  6. Oct 11, 2019 at 7:38 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I hear the dealer does good work
  7. Oct 11, 2019 at 7:48 AM
    Gruber1922
    Tacoma, WA
    2015 Tacoma Sport
    Thanks guys. I’ll do some checking for local places and see what I find
  8. Oct 11, 2019 at 8:07 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    Nothing like the original seal. mines been cracked on the passenger continues to grow for 6 years. If it goes to the driver’s side I might change it next spring when warmer weather returns.
  9. Oct 11, 2019 at 8:33 AM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Mines been cracked all the way across for almost 2 years now...Its low enough that it doesn't bother me
    I was always told SafeLights glass is not as strong as OEM, however OEM you'll be charged an arm and a leg more for it.
  10. Oct 11, 2019 at 8:46 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Windshields have to pass a ball drop test where a steel ball is dropped from specified height and has to be stopped by the vinyl interlayer. The glass manufacturer needs to select random samples and do tests at least daily- I can't remember the frequency. So the strength should be the same as they have to pass the test. Saying that, OE glass is better quality as far as scratches, edge chips, etc. For aftermarket, as long as it doesn't have a giant scratch it's good to go. OE is 100X more critical. But, OE glass is waaaay more expensive.
  11. Oct 11, 2019 at 8:49 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Not Safelite.
    outxider and wheeliest like this.
  12. Oct 11, 2019 at 8:49 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Windshield installation is not a regulated market, thus why so many leaking issues. Installers can "stuff" the windshield which is the fast way to install and cut corners. A good installer removes trim pieces so they set the glass in place, rather than slide it.
    & majority of safelite is bad, some good techs do work for them.
  13. Oct 11, 2019 at 9:38 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Had my windshield replaced by Payless Glass this summer.
    In Connecticut Insurance covers the replacement.
    Cost $280.00 if my old brain is working today.
    Tech was great , did it in my driveway.
    Tech indicated that in this East Coast area Safelite coordinates the repairs even though Payless did my repair.
    No leaks, and the gasket has a diffrent shape probably for streamlining and rain dispersing.
    2013 TRD Sport Access Cab
    TOMB
  14. Oct 11, 2019 at 10:39 AM
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    Dealers typically sublet the work out to a mobile autoglass company. It's incredibly rare a dealer has a glass tech on the payroll.
  15. Oct 11, 2019 at 10:49 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    This...
    I had mine replaced earlier this summer by SafeLite in my driveway with me watching. The tech did a great and meticulous job and while it was pricey, I have no complaints. I think it was $422 installed at my house.
  16. Oct 11, 2019 at 10:53 AM
    wheeliest
    Json
    TMPE AZ
    San Tan Ford (big ford dealer in AZ) has a full glass department with 6 employees
    Arizona is known for broken windshields.
    https://www.santanford.com/San-Tan-Ford-Auto-Glass.html
  17. Oct 11, 2019 at 10:56 AM
    SmokeyTacoAZ
    SmokeyTacoAZ Well-Known Member
    2018 DCSB TRD 4x4 OR
    Do you have glass coverage? Your insurance agent agent can probably recommend someone. Either way if it leaks the installer should have to fix it.
    I wanted OEM glass on mine but the dealers all subbed the work out to another third party (who wasn't likely to do OEM glass). Ironically it was the same company my insurance agent suggested. I think it'd be tough to provide a recommendation unless it's from someone local. All depends on the tech you get. The non OEM glass is fine I think.
  18. Oct 11, 2019 at 12:26 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Used Safelight twice on two vehicles. It's glass and I can see out.
    Steves104x4 likes this.
  19. Oct 11, 2019 at 7:41 PM
    3Dog
    3Dog good boy
    Rocky Mountain high...
    2015 Tacoma 4x4 auto TRD Sport DCSB
    Safelight only installs glass from other vendors, they don't manufacture their own glass.
