Cracking/BindingProblem after Bilstein install
Discussion in 'Suspension' started by markc6606, Dec 24, 2015.
  1. Dec 24, 2015 at 12:59 PM
    markc6606
    markc6606 [OP] Well-Known Member
    SoFlo
    '13 Off-Road
    So I put 6112's on my truck at the lowest setting when they came out last year. I'm still very happy with them but this has started bothering me.
    It has done this since the install but my OCD is getting the best of me. Only happens occasionally.
    Usually at full lock or close to it under somewhat acceleration forwards or reverse something binds up in front suspension,not in drivetrain,then let's go with a very loud pop or crack. I've had the truck in the air turn lock to lock both ways, tried it on the ground best I can and I cannot find where it can be coming from. I thought maybe the sway bar on coils but see no evidence.
    Too deep a noise to be a dust shield, almost sounds like something is grabbing then letting go. I can't find wear marks on anything that would be a clue. The coils themselves can't wind up on themselves somehow pop on the bottom flange can they??? I wouldn't think so.Hope you guys can give me some direction in where to look.
    If not, I live with it, no biggie I hope. Thanx everyone.
  2. Jan 3, 2016 at 10:24 AM
    markc6606
    SoFlo
    '13 Off-Road
    Bumpy. Anyone?
  3. Jan 3, 2016 at 8:08 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    Upper control arms hitting the spring?
  4. Nov 7, 2022 at 10:05 AM
    Caboose69
    Caboose69 Well-Known Member
    2011 Black DCSB Off Road
    Better late than never. I’m having exact same issue with my 6mo 6112s. Only driver side. I put my chassis ears on truck yesterday and located source of binding pop. It’s from the driver side spring. I’m not sure how to fix. I bought pre assembled from shock surplus. I don’t think it’s defective, just needs some type of adjustment.
    Any ideas to fix? I know I can disassemble and reassemble, and even then that may not fix. Looking for ideas….
  5. Nov 7, 2022 at 10:13 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Sounds like a CV to me. Are you sure it's the suspension doing this?
  6. Nov 7, 2022 at 10:15 AM
    Caboose69
    Yes. I spent 2 hours yesterday using the chassis ears trying different spots. Besides I’ve replaced both front lcas, axles, and wheel bearings at the same time I installed the 6112s.
  7. Nov 7, 2022 at 10:15 AM
    Caboose69
  8. Nov 7, 2022 at 10:26 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    have you re-torqued everything since the install?
  9. Nov 7, 2022 at 2:24 PM
    Caboose69
    Not everything, but will do precisely that tonight.
  10. Nov 8, 2022 at 9:26 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Check your caster/camber bolts for proper torque. Alignment shops are Famous for not tightening them down to the proper torque. I have experienced this with a 4runner before, symptoms were a suspension pop in the morning in reverse and turn and at other random times while driving. They were not torqued to the 130LB for it. I believe that 3rd Gen Tacoma's are 100LB.
    pnw_runnin likes this.
  11. Nov 13, 2022 at 9:43 PM
    pnw_runnin
    pnw_runnin Well-Known Member
    Louis
    Covington, WA
    2022 Tacoma OR DCLB, 2016 4R Trail
    Good suggestion. Here are some of the 3rd gen torque specs for the front end. Hunted them down after trying to get rid of clunking on my setup. Sadly, torquing everything didn’t do it.
    https://www.tacomaworld.com/threads/3rd-gen-torque-specs.454603/#post-14386328
  12. Nov 14, 2022 at 8:06 AM
    Caboose69
    Well I put my chassis ears on the front driver side frame mount. I did some more reading here at TW about them causing very similar issues like mine. I was getting a lot of sound from that mount that could easily transmit to the strut spring through the frame. Plus a visual inspection shows mild lack of uniformity between the driver and passenger side.
    it looks like replacing the bushings is relatively easy and cheap, so I’ve decided to replace it and see if that helps. It probably needs replacing anyway. My truck is at 190k miles.
  13. Nov 14, 2022 at 8:18 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Common pop is the lower control arm bolt/nut not being torqued down properly. I have been a victim of that.
