cracking noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco89, Apr 25, 2011.
  1. Apr 25, 2011 at 6:39 AM
    Taco89
    Taco89 [OP] Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    i just lifted my truck last week and put some 33's on it...after installing my lift i've been hearing cracking noises when i slow down and make a turn(sounds like its coming from the hood but sometimes sounds like its coming from the bed). anybody have any ideas why it does that?
  2. Apr 25, 2011 at 6:44 AM
    Taco89
    Nik
    Charlotte, NC
    nah i took the mud flaps off....i have the bilstein 5100's set at 2.5 with the toytec top plate spacer kit with 2" AAL in the rear
  3. Apr 25, 2011 at 6:45 AM
    Taco89
    Nik
    Charlotte, NC
    i also have the LT UCA's
  4. Apr 25, 2011 at 6:47 AM
    Taco89
    Nik
    Charlotte, NC
    i think they are 1/2" on both sides....it said it gives you approx. 3/4" lift
  5. Apr 25, 2011 at 7:00 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
  6. Apr 25, 2011 at 7:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What kind are these?
  7. Apr 25, 2011 at 8:59 AM
    Taco89
    Nik
    Charlotte, NC
    I meant LR ha
  8. Apr 25, 2011 at 9:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok.. as mentioned, re torque all the nuts/bolts on the UCA, LCA, and Spindle.
  9. Apr 25, 2011 at 9:02 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    it could be your upper control arms...they might need some grease
  10. Apr 25, 2011 at 9:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The noise associated with lack of grease is a squeak. Most creaking sounds are attributed to loose nuts/bolts.
  11. Apr 25, 2011 at 9:33 AM
    Taco89
    Nik
    Charlotte, NC
    Alright I'll check it tomorrow and let y'all know
  12. Apr 25, 2011 at 5:41 PM
    Taco89
    Nik
    Charlotte, NC
    So I found out what the problem was. A nut was missing from the bottom of the rear passenger shock... I'm guessing the dude who did my alignment last week did something to my truck because about 45 minutes in he covered the garage door halfway with a tarp and then closed the garage door behind it. He was sketchy
