cracking/squeaking noise coming from dash? Please help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeryV, Jan 22, 2013.
  1. Jan 22, 2013 at 4:49 PM
    GeryV
    GeryV [OP] New Member
    Gery
    EL Monte CA
    2010 preRnr V6 Taco Sport
    newbie to this forum, seeking some help or suggestions from fellow taco owners.. I have a 2010 v6 taco 4dr sport ed. and have this very annoying cracking or squeaking type sound that drives me nuts when I drive down the road, have tried to locate it but have no clue. Thought it might be the rearview mirror base and tightened it but doesnt fix the sound. Also seems to do it sometimes not all the time. Wondering if this is a common issue or if anyone else has the same problem....please help! thanx
  2. Jan 22, 2013 at 4:57 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Probably the windshield. Mine cracks and pops all the time when the temperature changes.
  3. Jan 23, 2013 at 4:20 AM
    prerunner11
    prerunner11 Well-Known Member
    MD
    2011 Magnetic Grey Prerunner Dbl Cab Sport
    Softopper
    My truck just started doing this about a month ago. No idea where it's coming from. I'll start pushing on the dashboard above the steering wheel to try to get the noise to replicate, resulting in nothing.
    It doesn't matter what speed I'm going either. It's happened from 20 mph to 65 mph.
    It was cold when it happened, but nothing out of the ordinary.
  4. Jan 23, 2013 at 5:04 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The dash is plastic touching plastic which squeaks eventually. The fix is normally adhesive backed felt.
  5. Jan 23, 2013 at 8:53 AM
    GeryV
    Gery
    EL Monte CA
    cool thanks for all the great advice, gona check all these ideas out thanks a bunch!
  6. Jan 23, 2013 at 9:14 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If your truck is under warranty, go to the dealer and they'll diagnose and hopefully fix it. There are a couple well known dash rattle / pop - tick issues that can be easily fixed by TSB's.
  7. Oct 18, 2014 at 7:37 AM
    natemcdaris
    natemcdaris Member
    Just had same problem after searching found a hair line crack causing the noise. This is on a 2012 module with 34k
