Craftsman chain saw won't start!
Discussion in 'Garage / Workshop' started by 05RedTaco, Jan 28, 2012.
  1. Jan 28, 2012 at 9:00 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have not even a year old Craftsman chain saw, 2cycle 42cc motor, 18" bar. It worked OK until now. Since day one, after it got hot from few hours of use it wouldn't start. It would always start the next day though. I used it a LOT last night for about three hours. It died yesterday and wouldn't start. I couldn't finish the job :mad:!
    This morning I go finish the job and it won't fire! I spent an HOUR trying to get it to run. I checked the air filter, which is clean, checked the carb which is clean and getting fuel. Checked the spark plug which sparks. It has brand new gas with 40:1 mix.
    The only thing I can think of is that it doesn't have enough compression to start.
    Any ideas???
  2. Jan 28, 2012 at 9:12 AM
    YoaterBoater
    YoaterBoater Well-Known Member
    Running tubes, Toolbox
    Most common mistake: Killswitch haha. Everything sounds right though. You have taken the carb off and cleaned everything throroughly?
  3. Jan 28, 2012 at 9:20 AM
    Tacoma Mike
    Southern Maine
    All new mowers/ saws etc are built with the carbs so lean they hardly run.
    I've had to drill my mower/ saw /weed whacker carbs to get to the adjustments just to get them to run ok. Not an easy thing to do.
    My suggestion is to get a new plug. put 4 or 5 drops of fuel down the plug hole. install the plug and try it.
  4. Jan 28, 2012 at 9:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've had a hell of a time the last few years with the ethanol and small engines. The ethanol plays hell on the carbs, sometimes fuel additives help.
  5. Jan 28, 2012 at 10:09 AM
    Tacoma Mike
    Southern Maine
    ???? That never happens.......................................:annoyed:
  6. Jan 28, 2012 at 10:11 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    usually this
  7. Jan 28, 2012 at 10:13 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Unfortunately, I know a few people that just don't have good luck with Craftsman chainsaws. My father in law seems to always be battling to get his to start.
  8. Jan 28, 2012 at 10:24 AM
    05RedTaco
    Tony
    Scottsdale
    I put fuel in the spark plug hole. Same result. Won't start not even sounds like its attempting to start...
    I think even if carb would be clogged or bad, with fuel in the cylinder it "should" start and run for few seconds.
    I think this saw is toast :mad:
  9. Jan 28, 2012 at 10:41 AM
    05RedTaco
    Tony
    Scottsdale
    Now even if the fuel mixture wasn't exactly right the saw should still start right?
  10. Jan 28, 2012 at 10:45 AM
    ffbartlett
    ffbartlett Well-Known Member
    southern california
    2011 Reg Cab 4x4
    tint, bfg's, 5100's, tunnel cover.
    try takin the plug out and given it a few pulls. is there a fuel filter in the gas tank?
  11. Jan 28, 2012 at 10:48 AM
    05RedTaco
    Tony
    Scottsdale
    Already did that dont know if there is a fuel filter...
  12. Jan 28, 2012 at 10:49 AM
    Tacoma Mike
    Southern Maine
    It should at least try.
    you have spark you said
    air filter not plugged
    does it seen to turn over easier than before ??
    could have seized the rings in the piston for no compression.
    most of the crap now is use and throw away.
  13. Jan 28, 2012 at 10:52 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    when it died, what happened exactly?
  14. Jan 28, 2012 at 10:55 AM
    05RedTaco
    Tony
    Scottsdale
    Can't notice much difference in how hard is it to pull... I would say its tad easier...
    Yes good point I should have bought a better quality saw... I thought that if I use it once a month it would be ok... Guess not.
    It has 2 year warranty, I will take it to Sears service center and see what they say.
    Funny thing is that in the morning I tried to start it and it fired. I shut it off, hour later won't start at all, not even sounds like it tries to start.
    I am thinking even if it was straight gas and no oil, it should still start, just wouldn't run very well and would burn up the engine... BUT I put oil in the gas...
  15. Jan 28, 2012 at 11:01 AM
    TACOMABOSS
    96 SR5 4x4
    piston could have scored the cylinder walls. if the its a little easier to pull that might be the case. take it to a saw shop and have them look at it?
