Craiglist autobody.....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BalutTaco, Dec 9, 2019.
  1. Dec 9, 2019 at 2:53 PM
    #41
    BalutTaco
    BalutTaco [OP] Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    ye no bc or cc should i do that myself? Will primer last by itself without bc/cc
  2. Dec 9, 2019 at 3:01 PM
    #42
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    No primer will not last. Primer isn't water proof (protective), it will rust relatively fast. It needs to be painted and clear coated. You should also apply chip (rock) guard, to match existing chip guard.
    Big tall dave likes this.
  3. Dec 9, 2019 at 3:03 PM
    #43
    BalutTaco
    Is it kinda to late to apply Clear coat? I don't really mind not having matching paint
  4. Dec 9, 2019 at 3:15 PM
    #44
    na8rboy
    WI
    If you plan on doing yourself. You should apply chip/stone guard first, then paint, followed by clear. You can get all three in spray cans. Either from a good auto parts store, or auto paint supply store. Clearing over primer, is a crap shoot if it will hold up. Don't know what the guy used, for prime - Lacquer, enamel, or epoxy.
  5. Dec 9, 2019 at 3:18 PM
    #45
    na8rboy
    WI
    Most factory's and auto body shop use Wurth, or SEM paintable chip/stone guard.
    JS760 and Itchyfeet like this.
  6. Dec 9, 2019 at 3:19 PM
    #46
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If you can spray WD40 into a hole, you can do this too.
    Not sure where you are located, but if you have rust in your area then its a good idea to spray inside all the things and inside the frame.
  7. Dec 9, 2019 at 3:19 PM
    #47
    BalutTaco
    Maybe i'll go to a auto body to get it fix.... well to get it painted since most of the work is done.
    na8rboy[QUOTED] likes this.
  8. Dec 9, 2019 at 3:23 PM
    #48
    na8rboy
    WI
    :thumbsup:
  9. Dec 9, 2019 at 3:25 PM
    #49
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    rattle can clear coat if you really don't want to spend the coin getting a shop to paint it.
  10. Dec 9, 2019 at 3:37 PM
    #50
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    You should probably just pay to get it done right, especially if it isn't cleared. It'll pop off their sliders will be in the way for the shop to do it right and just be a bigger Hassel later.
    Chew and na8rboy like this.
  11. Dec 9, 2019 at 3:55 PM
    #51
    BalutTaco
    I need something tempt for right now...
    Skydvrr[QUOTED] likes this.
  12. Dec 9, 2019 at 4:01 PM
    #52
    Itchyfeet
    Itchyfeet Well-Known Member
    Body supply shops, good ones will mix factory colors and put them in spray cans on site.
    I'd do that for now, but get it fixed right later. Putting sliders to hide the damage is the same shit people do when they shit their pants.
    The bondo and added holes are going to soak water up like a sponge
  13. Dec 9, 2019 at 4:04 PM
    #53
    BalutTaco
    MAACO IT IS!
    Skydvrr likes this.
  14. Dec 9, 2019 at 4:11 PM
    #54
    Timetraveler66
    Timetraveler66 Well-Known Member
    I have a set of theater speakers I was supposed to deliver to a big chain movie theater. But my invoice only showed 6 pair and I have 8 pair. I'll sell you a set for a tenth of the invoice price. Will deliver them to you in my white van and while I'm there I will seal coat your driveway. Never ever ever cheap out. If it's too good to be true !
    CG256, whatstcp, Chew and 1 other person like this.
  15. Dec 9, 2019 at 4:12 PM
    #55
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    Wait, what? People put on sliders to hide that they shit their pants? Huh, who knew?
    bigmw, whatstcp and shane100700 like this.
  16. Dec 9, 2019 at 4:49 PM
    #56
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    Did he use body filler or roofing tar. Johnson brothers can lay the tar really smooth then all you need is paint. Ops
    BalutTaco[OP] and Skydvrr like this.
  17. Dec 9, 2019 at 4:50 PM
    #57
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    How much Bondo and aluminum foil did the Gypsy use?
    JS760, whatstcp, GreyBaldTaco and 2 others like this.
  18. Dec 9, 2019 at 8:33 PM
    #58
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    He paid $400... so by deciphering the craigslist code of unethical bodywork I would estimate it at $3.00 bondo and $1.00 aluminum foil.
    What I see missing is a CA prop 65 sticker on the repair. Both of those materials, as well as primer, are known to the state of California to cause cancer, birth defects, earthquakes, homelessness, high housing prices, and traffic 24/7.
  19. Dec 10, 2019 at 12:18 AM
    #59
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Should've used ramen noodles.
  20. Dec 10, 2019 at 2:34 AM
    #60
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    FYI- If you go to a proper body shop now, make sure they grind it down to bare metal and start fresh. You never know what that Craigslist-guy used underneath the primer/Bondo and you don’t want the body shop to just add more filler onto his shitty repair.
    If it was me, i’d do what others have suggested and rocker guard the entire side, then buy a can of colour matched paint, watch a few videos and blend it myself. Fluid Film inside the rocker and hope the shitty repair lasts a few years.
    BalutTaco[QUOTED][OP] and Chew like this.
