Crank but no start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacotuesday29, Jan 21, 2019.
  1. Jan 21, 2019 at 7:53 PM
    tacotuesday29
    tacotuesday29 [OP] Well-Known Member
    17 OR DC
    No. Once it started it everything was normal.
    wilcam47[QUOTED] likes this.
  2. Jan 22, 2019 at 12:41 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Obviously Not... Light Does Not stay on because of user error!
  3. Jan 22, 2019 at 5:56 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    A hard start once in a blue moon isn't indicative of a damn thing, hot or cold.
    Gunshot-6A likes this.
  4. Jan 22, 2019 at 6:44 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Jan 22, 2019 at 6:58 AM
    McKBrew
    McKBrew Active Member
    Jess
    North Idaho
    2018 TRD OFFROAD DCSB Quicksand
    I think that the push start may have a slight delay compared to the key starts that most of us are probably used to. I've had a couple instances where I've pushed the button and it's started to turn over and I shift into reverse before it catches. Engine won't start until I shift back into park and try again (and the check engine light/other indications show up). I don't consider it a problem but it just reacts a bit slower than previous vehicles.
  6. Jan 22, 2019 at 8:03 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Inferring from the description of snow my initial theory would be that a cold battery may be the problem, but not something to worry about too much.
    Ther first start may have consumed what little power the battery had......had you run it longer the alternator would have charged the battery and the battery would have come up to temperature and thus worked within its optimal range.
    In your case a cold battery may point to the issue you had, and the difference between the two cranks may have been minute and impractical to measure. Just a theory.
  7. Jan 22, 2019 at 8:10 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    How long were you cranking during the no starts?
  8. Jan 22, 2019 at 9:32 AM
    rightsideout
    rightsideout Active Member
    COS
    '17 Tacoma TRDOR DCSB AT BBP
    XD HID lows, LED fogs, 4R pro wheels, BFG KO2s, Clazzios
    I had something similar happen to me once and once only so far.
    My truck was cold, parked it the night before in the driveway. Next morning got in an tried to start it, it cranked for what seemed like a set amount of time with the push button and then would stop cranking and displayed the battery error. Tried it again twice, same exact thing. On the last try I tapped the gas pedal just a bit and it started up. No problem since.
    It was maybe 20 degrees outside, so it wasn't that cold.
    What got me was that it happened to be the same time that one of my recently installed XD HID lights failed to illuminate. But the thing was cranking fine, so it had to be just a fluke with gas getting through. Ended up later on tracing the HID issue to the relay being faulty. I believe in coincidences but think true coincidences are rare, I guess this was a real one.
    Anyways, I agree that if it happens again, it's a problem. One time, I would not be concerned.
  9. Jan 22, 2019 at 1:37 PM
    tacotuesday29
    17 OR DC
    Thanks for the input. Hasnt happened today so it may be a one time issue. Just odd that it ran two 15 min periods earlier that day with no issues then have the front end up and no start after running for 2 mins
  10. Jan 22, 2019 at 1:39 PM
    Rujack
    Still wondering how long you were cranking...
  11. Jan 22, 2019 at 1:42 PM
    tacotuesday29
    17 OR DC
    Sorry i was holding the button for about 5 seconds. (Was saying in my head the second not start one Mississippi) the third time which actually started it took about 3 seconds.
  12. Jan 22, 2019 at 1:44 PM
    Rujack
    Gotcha. Yea, I wouldn’t worry much unless it does it again soon.
  13. Jan 22, 2019 at 1:46 PM
    tacotuesday29
    17 OR DC
    Thats the plan. Just concerned on a 12k mile truck lol.
  14. Feb 18, 2019 at 7:44 AM
    mstrbrc
    mstrbrc Well-Known Member
    ABQ
    '16 DCSB OR MT
    Something similar has happened to me...
    A couple months ago I had just left my house (cold engine) and realized I forgot to grab something, so I started backing up to the driveway and stalled out (MT reverse problems), tried to restart and engine just cranked, tried this a couple of times and the engine would just crank. Finally, on the 3rd or 4th try, it started back up.
    I thought it might be that the battery was going bad, so I let it sit overnight and tested the voltage in the morning, it was a little low, but nothing extreme, but I decided to get a new one from Costco anyways.
    Truck has run fine until this morning, was backing out of the garage (cold engine) and thought I had put it in neutral while I was waiting for the garage to close and stalled out (as I was still in reverse). Tried to turn the truck back on and it would just crank; also got a low oil warning on the dash (driveway is not angled at all)... Anyways, tried to start again and it just cranked for awhile and then it sputtered to life and continued sputtering for a couple seconds afterward (think, rough idle). The low oil warning did not reappear and I was able to drive off just fine.
    There is something odd about shutting down/stalling a cold engine and it not being able to restart right away, but I’m not too sure what the connection is... it doesn’t seem like this should be normal operation, but I have a feeling, with these trucks, it is.
    Prove me wrong.
  15. Feb 18, 2019 at 7:49 AM
    #35
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Lol, are you serious? It’s so much easier for an engine to start warm/hot vs cold. In fact, the first thing I do when I go to buy a used car/truck/motorcycle is see if the motor is warm. If it’s warm, I tell the guy I’ll be back in an hour so I can see how it starts when it’s cold.
    JCOOR likes this.
  16. Feb 18, 2019 at 3:38 PM
    #36
    joshwho44
    joshwho44 New Member
    Josh
    2017 TRD OR M/T Inferno
    If I stall my 17 MT while cold it won't restart for 45-60 seconds, although it feels like forever. This has happened a few times backing out of the driveway when it's really snowy/icy. Sometimes it stores a code for the failed start, other times it doesn't. I'd love to know what's going on.
  17. Feb 18, 2019 at 3:43 PM
    #37
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    I have stalled my 18 MT a few times in different situations but it always starts back up easily. Not quite like before a stall but it’s never seemed like something to be concerned about
  18. Feb 18, 2019 at 3:46 PM
    #38
    tacotuesday29
    17 OR DC
    Mine is an automatic
  19. Feb 18, 2019 at 4:22 PM
    #39
    Hobbyman2007
    Hobbyman2007 Member
    Denis
    Dowling Ontario canada
    2019 taco TRD sport
    Wow, I’d get it checked . Absolutely no reason for a no start hot or cold . If the engine is stalled out after being lugged that’s one thing . Shutting it down and then a failure to restart plus a check engine light . That says bring it to the dealer .
    After a stall out , the cylinders still have unburnt gasoline it them causing an overly rich condition . It’s called stoichiometric ratio. Overly rich (too much fuel) or lean ( not enough fuel ) will cause a no start. Typically the fuel after a stall evaporates then the vehicle will start .
  20. Feb 18, 2019 at 5:16 PM
    #40
    joshwho44
    Josh
    I left the truck with them when I got the first free oil change. As per the usual dealer routine, the couldn't replicate.
    I need to try and replicate the problem while the OBDlink is hooked up and logging data...Regarding stoich, this was soon enough after starting the truck it was still running cold start enrichment.
