Crank no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPreRunner1998, Oct 15, 2019.
  1. Oct 15, 2019 at 10:32 AM
    TacomaPreRunner1998
    TacomaPreRunner1998 [OP] New Member
    1998 Tacoma prerunner v6 2wd
    bolted on some crap
    Today i started my truck twice without issue. The second time i heared a rattling noise for a second from down the drivers side when i took off and then i parked at a store for a few minutes then when i came back it would crank but no start. I check for codes since i already had check engine light on and no codes other than P0758. I feel like it could be the gas not getting to the engine but how could it be if i was just driving it just fine? I could use some help on what it might be and if i could start it atleast once more so i can take it home.
  2. Oct 15, 2019 at 10:38 AM
    TacomaPreRunner1998
    bolted on some crap
    It could be spark plugs but the engine doesnt even attempt to turn over. Just a constant crank as if it had no fuel getting into the engine. The cat converter was replaced 2 years ago so i dont think its backed up. But its possible maybe an air sensor but again no codes related the fuel or air sensors
  3. Oct 15, 2019 at 10:44 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Maybe a starter bolt backed out. See if the starter is leaning away from the trans housing.
  4. Oct 15, 2019 at 12:00 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    So our engine is turning over while you hold the key to start just fine? Just not firing up?
  5. Oct 15, 2019 at 12:28 PM
    TacomaPreRunner1998
    bolted on some crap
    Starter is in normal position
    Yeah theres load on the starter, the starter works fine just the engine doesn't have spark
  6. Oct 15, 2019 at 1:46 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Is it cranking unusually quick?
  7. Oct 15, 2019 at 1:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Starter is on passenger side for a V6.
    I'm leaning towards broke timing belt.
    wilcam47 and cruiserguy like this.
  8. Oct 15, 2019 at 1:58 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    That's why I asked if it's turning over faster then usual...broken belt or a sheared crank pulley key. Turns over quicker since a good number of valves are open.
    Jeff
    cruiserguy and koditten like this.
  9. Oct 15, 2019 at 5:45 PM
    cruiserguy
    Elijah
    SEKS
    Is knock sensor a possibility based on the symptom he's describing?
  10. Oct 15, 2019 at 8:59 PM
    YeastLords
    YeastLords New Member
    2002 4x4 Double Cab 5VZFE
    Your fuel pump could have gone out
    JC15Taco and wilcam47 like this.
