Crank, no start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Part-time Tinkerer, Mar 28, 2022.
  1. Mar 28, 2022 at 7:27 PM
    Part-time Tinkerer
    Part-time Tinkerer [OP] New Member
    Clifton
    09 Tacoma 6 cyl
    Need a hand...
    Changed the fuel pump bout a month n a half ago...no problems. Truck quit while in a drive thru. Battery tested bad, changed, alternator tested bad, changed...will crank but not start. Checked fuses...good, fuel pump relay...good. Disconnected fuel lines to check..when cranking, fuel squirting out (found a pressure tester a while back that didnt have proper attachments n couldnt find one local, so im doing it this way). When i disconnected mass airflow sensor n cranked, started for a second or two but dies. Disconnected the plug to throttle body n cranked, it started for about 10 seconds and died. Thinking this is throttle position sensor, but i changed throttle body maybe 3 years ago.
  2. Mar 28, 2022 at 7:29 PM
    Bishop84
    Bishop84 Well-Known Member
    No codes?
    Why did you change the fuel pump?
    Spark?
    b_r_o and Dm93 like this.
  3. Mar 28, 2022 at 7:34 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is your security light flashing with the key on?
    TnShooter, Bishop84 and Jimmyh like this.
  4. Mar 29, 2022 at 7:47 AM
    Part-time Tinkerer
    Clifton
    09 Tacoma 6 cyl
    At first, no codes except o2 sensors. They were changed about 3 yrs ago. After i tried to reset ecu n security yesterday, now the mass airflow sensor n throttle position sensor codes coming up. Changed the fuel pump because it was losing power n eventually wouldnt stay crunk after running out of gas. And by spark, do u mean checked spark plugs? Havent lately, but they were changed about 3 yrs ago as well. Ill check them next.
    As for the second comment, i didnt pay attention to the security light until after i tried the resets. Im not near it now, but the light was blinking without the key in...ill have to check to see if it blinks with the key turned.
  5. Mar 29, 2022 at 11:51 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That may be the problem there. What codes where they? You remember the # ?
    Do still check this. It’s easy to check.
  6. Apr 2, 2022 at 9:30 PM
    Part-time Tinkerer
    Clifton
    09 Tacoma 6 cyl
    Update...it was the fuel pump. Just changed the sucker about a month n a half ago. When u spend $80 on a fuel pump, i guess u get what u pay for. Got a warranty this time
