Crank / no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Steelers, Sep 24, 2023.
  1. Sep 24, 2023 at 7:09 AM
    Steelers
    Steelers [OP] Member
    2001 Taco
    Would a bad MAF sensor cause a no start. I replaced fuel pump and same situation.
  2. Sep 24, 2023 at 8:21 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check for spark
    Check for fuel pressure
    wilcam47 likes this.
  3. Sep 24, 2023 at 8:27 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Unplug it. If it starts prob the issue..
  4. Sep 24, 2023 at 8:47 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Can't say I've ever heard of that, but I guess it could be possible in the right circumstances. More than likely you have another issue though.
  5. Sep 24, 2023 at 9:03 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    MAF sensor doesn't come into play until at least a few seconds after running.
    On startup the pcm only looks at coolant temp sensor
    You need to do some testing
  6. Sep 24, 2023 at 10:12 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    v6 or 4cyl? Timing belt good? Check compression.
  7. Sep 24, 2023 at 1:59 PM
    Steelers
    2001 Taco
    It’s a 4 cylinder (2.7)
  8. Sep 25, 2023 at 12:14 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    confirming compression is where i'd start. If thats good, try a shot of ether to see if it trys to start.
