Crank position sensor melt down :reason for truck just dying
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacolady00, Dec 24, 2017.
  1. Dec 24, 2017 at 11:48 AM
    Tacolady00
    Tacolady00 [OP] Active Member
    Karen
    2017 Toyota Tacoma TRD Off-Road
    Grill hood predator bars taillights
    I have a 2017 Toyota Tacoma TRD off road. 4000 miles on it. Brand new. I was driving and it just cut out. Choked. Died. Could start it again 10 min later got it home. Started it the next day was fine drove three blocks it died on side of road. Sent up warnings like low oil pressure. And high temperature fluid temperature. Checked the oil had barely any on the dipstick went and bought some came back to my truck checked the oil again and it registers as fine. Added a little anyways to be safe. Not much but what in the ever loving hell is wrong??? Toyota will have to come and get it Tuesday but for now I am screwed. Any ideas guys. Please help. I am a girl but I do understand shit if you tell me. Please help
  2. Dec 24, 2017 at 11:52 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Looks like the crank position sensor failure.
  3. Dec 24, 2017 at 11:53 AM
    Tacolady00
    Karen
    Ok. I honestly have never heard of that is it a simple fix for Toyota then?
    scottalot likes this.
  4. Dec 24, 2017 at 11:54 AM
    FFBlack
    2019 TRD OFF ROAD
    Yes , very easy and welcome to Tacomaworld and Merry Christmas!
  5. Dec 24, 2017 at 11:54 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    You might change the title to LOW OIl Pressure. What do I do?
  6. Dec 24, 2017 at 11:56 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    check the dipstick 3-4 times each time. Dont rely on one pull
  7. Dec 24, 2017 at 11:57 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    yes if its a bad sensor its a very easy fix for them, the truck should be fine im sure no damage has been done that's why it shut down because the computer senses somethings wrong and shuts down, its called Limp mode. don't worry let the dealer take it and fix it you should get a loaner if necessary.
  8. Dec 24, 2017 at 11:58 AM
    Tacolady00
    Karen
    Checked it five times to be sure. I just read up on the crank position sensor failure and that is EXACTLY WHAT IT IS Thanks so much!
  9. Dec 24, 2017 at 11:58 AM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
  10. Dec 24, 2017 at 11:59 AM
    BillsSR5
    bill
    2014 SR5
    easy fix
  11. Dec 24, 2017 at 1:02 PM
    Tacolady00
    Karen
    I am getting a new one right now. Toyota will pay for it. Lol. Already got that all settled. Where the ever loving he’ll is it located in my 2017. Any one have a pic?
    FHC and scottalot like this.
  12. Dec 24, 2017 at 1:05 PM
    Pigpen
    Dan
    Northwest Montana
    Please go to the top of your post, at the corner. Click "thread tools" and change the title. Help means you need someone to come help you. Glad you're getting your problem resolved. Welcome to TW!
  13. Dec 24, 2017 at 1:13 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    With a 17, I would take these pictures and the truck back to the dealer on Tuesday and say WTF-fix my shit.
    Good luck keeping rolling over the long weekend.
    edit to remove 3rd gen forum reference-i see you caught it a while ago.
  14. Dec 24, 2017 at 1:20 PM
    Tacolady00
    Karen
    I can’t get it to Toyota tho?!?? With out new part. And how the hell can I move to the third gen page?
  15. Dec 24, 2017 at 1:29 PM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    The sensor is on the block, behind the wheel well splash panel, the passenger side front. There is a diy thread and write up in the 3rd gen forum. It has pics and all. Seems real easy to do. Just have to take tire off for better access and room. Good luck with it. Hope this helps.
  16. Dec 24, 2017 at 1:31 PM
    Tacolady00
    Karen
    Thank you. I’ll try and find what you said. I am new to this forum so I’m not sure how to look for that. But I’ll try and figure it out
    wilcam47 and shakerhood like this.
  17. Dec 24, 2017 at 1:34 PM
    Boneretreiver
    Tom
    Eastern WA.
    What i did was type cps location in the search box, upper right side of the page. Then just started looking and found a diy write up for 3rd gens.
  18. Dec 24, 2017 at 1:39 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good Luck, classic symptom of CPS failure, Toyota will cover getting it towed in to the dealership and should give you a loaner but that is if they are even there on Christmas Eve.
  19. Dec 24, 2017 at 1:49 PM
    Tacolady00
    Karen
    That’s the problem. No one till Tuesday
    shakerhood likes this.
  20. Dec 24, 2017 at 2:01 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Assuming you have a new repalcement CPS, it's like a 10min job. Pop the passenger side splash guard off(inside the wheel well) 10mm socket on an extension; pull the old one out/ new one in. I would disconnect battery during the process so the computer resets all codes.
    Tacolady00[OP] likes this.
