Crank positioning sensor...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solidal67, Jun 25, 2019.
  1. Jun 25, 2019 at 10:39 PM
    Solidal67
    Solidal67 [OP] Member
    Allen
    2006 4dr. Tacoma sport 4.0
    After a long battle with this 06 Tacoma not running at all , I changed out the crank sensor on this 4.0 , sure enough fired right up. After a day or 2 it started throwing crank positioning sensor code again and idle was rough, now it runs for a while and dies , takes some doing to get it started again only to repeat the same actions. Does anyone have any clue ? Computer brain? Cam sensor ? Bad crank sensor ? Help please. I'm at my witts end.
  2. Jun 26, 2019 at 5:10 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Post all of the codes you've pulled. Did you replace the CPS with a brand X version or factory?
    Torspd likes this.
  3. Jun 26, 2019 at 6:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Exactly what Lester asked.
  4. Jun 28, 2019 at 8:28 AM
    Solidal67
    Allen
    It was a cheaper one from A1 auto parts online which had really good reviews. But yes, it was an after market cps. All the codes are saying CPS. thinking it might have been, I also replaced one of the cam sensors with an after market one also. Think I should go through and replace them with OEM product before I go any further trying to diagnose this ?
  5. Jun 28, 2019 at 10:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How are the wires to the CPS? Melted, cut, exposed?
    Have you any wiring modifications on your truck, which may have tapped into that circuit?
    b_r_o likes this.
  6. Jun 28, 2019 at 12:46 PM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    OEM sensors only.
  7. Jun 28, 2019 at 12:53 PM
    Solidal67
    Allen
    No mods, stock all the way. Never had any over heating issues. Never any issues at all until this
  8. Jun 28, 2019 at 12:55 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    How about the VVTi sensor? Iirc, there were a few members here who had a few dirty VVTi sensors, and ran like crap until they cleaned/replaced them.
  9. Jun 28, 2019 at 2:00 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Who makes them?
    Its not actually toyota is it?
  10. Jun 28, 2019 at 3:13 PM
    Lester Lugnut
    Over the years I've seen the Denso brand name on many Toyota sensors. Here's one for the '06 Tacoma 4.0L
    https://www.densoproducts.com/product.aspx?zpid=40062
    Further down is a pointer to a Toyota Factory Service manual for 4/6 cyl 2nd Gen Tacoma's - do a FIND for "crankshaft position". You'll get hits for both the 1GR-FE(6 cyl) and 2TR-FE(4 cyl) engine. There's an ohm test you can perform. I would do this before condemning the 1AAUTO part. I mentioned after-market above because a lot of those that are electrical/electronic in nature are cheap Chinese junk. Can't speak from experience about 1AAUTO parts, but they have put together a lot of useful videos:
    http://www.customtacos.com/tech.old/files/05FSM/repair.html
