Crank Pulley and both Idler Pulley Torque?
Discussion in '1st Gen. Tacomas (1995-2004)' started by B-Field, Jun 22, 2010.
  1. Jun 22, 2010 at 11:12 AM
    B-Field
    B-Field [OP] Member
    Kyle
    01 PreRunner Limited
    I'm installing my crank and both upper and lower Idler Pulley and need to torque them to the right spec. I cant seem to find the spec any where. Can could you possibly guide me on the proper torques and how to apply the proper torque on the crank so that i dont change the timing on the truck?
  2. Jun 22, 2010 at 11:18 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    what motor are you running?
  3. Jun 22, 2010 at 11:18 AM
    TKGN1
    TKGN1 Well-Known Member
    Todd
    College Station, TX
    '01 DC TRD 4wd
    SAS on links, SC, flat bed
    Is your timing belt on or off right now? It should not change timing if the belt is on, crank pully is keyed to the crank.
    I didn't torque mine to a spec, put locktite on the threads and tightened them good and tight.
  4. Jun 22, 2010 at 11:23 AM
    B-Field
    B-Field [OP] Member
    Kyle
    2001 V6 Tacoma Prerunner. All belts and pulleys are off with the exception of the cam pulleys. I'm doing a complete swap of all bearings, water pump and belts. Right now I'm going back together.
  5. Jun 22, 2010 at 11:34 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    good luck :)
    SilverGhost likes this.
  6. Jun 22, 2010 at 11:46 AM
    TKGN1
    Todd
    College Station, TX
    '01 DC TRD 4wd
    Put the timing belt on before you do anything else, you don't want to get the timing off. Make sure the marks on the tbelt line up with the cams/crank mark, hopefully you had the motor at TDC when you started the tear down. AFTER you have the timing belt on, put the tensioner on then complete the rest of the install. You can't put the crank bolt on until you have everything else put on along with the harmonic balancer.
    HTH
  7. Jun 22, 2010 at 11:55 AM
    B-Field
    B-Field [OP] Member
    Kyle
    Im asuming that your telling me to put the T-belt on so that when i do torque the crank bolt if the engine turns it turns everything in sync. How can i prevent the engine from turning?
  8. Jun 22, 2010 at 12:01 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    with a crank pulley holder.
    The actually toyota tools makes it super simple
  9. Jun 22, 2010 at 12:10 PM
    TKGN1
    Todd
    College Station, TX
    '01 DC TRD 4wd
    Yep, once you have the belt on it doesn't matter. You have to have the belt on in order to do a final torque on the crank bolt anyhow.
    I made a tool to keep the motor from turning when tightening.
