Crank Pulley Bolt Removal - Easy Way!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Jun 12, 2010.
  1. Aug 8, 2019 at 4:29 PM
    #61
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    This is the first way that I’ve seen it done and hasn’t failed me yet.
  2. Aug 8, 2019 at 4:56 PM
    #62
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    I would have totally done that however, I drained all of my oil and I am kicking myself.
  3. Aug 8, 2019 at 5:05 PM
    #63
    Da Boogie Man
    Seymour
    Even if it were full of oil, you aren’t turning the crank enough for the oil pump to do anything. You are just bumping the starter.
  4. Aug 9, 2019 at 6:49 AM
    #64
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Engine rotation: yes CW (viewed from front) is standard, but some 1990s Honda engines rotate CCW; always check before you assume it's CW.
    Lester Lugnut likes this.
  5. Feb 12, 2020 at 6:03 PM
    #65
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Slowly doing my homework on a supercharger install, so I'm reviving this thread. After reading this thread, it seems that for an automatic Tacoma, one way to do it is to do the bump starter method for the bolt removal and use the pulley holder tool to reinstall the bolt. That post where the bolts sheared freaked me out, but I'm thinking the shear stress is greater on the removal vs the reinstall of the bolt. Or is there a better way for the reinstall?
  6. Sep 15, 2020 at 6:53 PM
    #66
    alberttang
    alberttang Driver of 666Tacoma
    Phoenix, AZ
    2007 Tacoma DCSB TRD
    Reviving an old thread! Anyone have tips on the reinstall of the crank? I can’t seem to get it to line up with the notch!
  7. Sep 15, 2020 at 7:15 PM
    #67
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Is it having trouble going on or lining up? Are you using aftermarket such as NST or OEM? The OEM should be pretty easy if it’s the same one just rotate. Some aftermarket NST the notch is a tad tight.
  8. Sep 15, 2020 at 7:15 PM
    #68
    nudavinci64
    Robert
    I just too am impact and hit it. Came right off.
  9. Sep 15, 2020 at 7:17 PM
    #69
    alberttang
    Phoenix, AZ
    Well I didn’t want to torque it down if it wasn’t lined up perfectly, but I just eyed it and am starting to torque it down. How do you know if it was properly lined up? Will it not slide in otherwise? Just want to make sure before I give it the full 200 lbs of torque
  10. Sep 15, 2020 at 7:20 PM
    #70
    nudavinci64
    Robert
    you should feel it catch if you rock back and forth it should be in it. If it spins then no dice. Try a bit of grease to help ease it on. I needed to add a bit then give it a go. As long as it’s good and tight and the impact doesn’t move it ( 200 ish) it should be good. don’t go at it with a. Massive impact that would be all bad. Guten tight
  11. Sep 15, 2020 at 7:20 PM
    #71
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Not a hack job, but definitely a "hack".
    A hack job is a crappy job or a messy torn up result that's an eye sore at the end.
  12. Mar 2, 2021 at 9:01 AM
    #72
    chueflee
    chueflee Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    Do I need this tool if I already have the trd supercharger pulley on? But I wanna change the crankshaft pulley to a nst pulley?
  13. Feb 18, 2022 at 8:30 AM
    #73
    DRMetz
    DRMetz Well-Known Member
    Drew
    DMV
    05 PreRunner SR5 TRD Sport Rad Red
    This saved me. Thanks!
  14. May 6, 2025 at 5:21 PM
    #74
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    This thread has been revived a few times, and for good reasons. Here’s mine:
    When bumping the starter to remove the crank bolt, should the ratchet be set to tighten or loosen? It’s never mentioned but figured I’d ask, I don’t wanna F this up lol.
