Crank pulley bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fabio760, Jun 15, 2015.
  1. Jun 15, 2015 at 8:10 PM
    Fabio760
    Fabio760 [OP] Active Member
    01 prerunner
    fox shocks, ebc pads, baer rotors, brembo drums
    I can not for the life of me get this damn thing off torque wrench failed me as i cant keep from moving the pulley dont have a home made tool impact wrench cant budge it what the hell gives anyone else out there able to get it off somehow?
    Truck is an 01 tacoma im in the process of getting the water pump changes
  2. Jun 15, 2015 at 10:26 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You are using a torque wrench to remove the bolt? Not good. Use a breaker bar of some sort.
    Also, improved punctuation and capitalization would help a lot for us to understand what you are trying to say. Hard to make sense out of.
    If the crank pulley is rotating, then you need to either put it in Park (if you have an auto) or in gear (if you have a standard).
  3. Jun 15, 2015 at 10:34 PM
    Fabio760
    01 prerunner
    sorry typing with my pinkys makes things rather difficult (dirty hands). Torque wrench was used because its what was available theory being that if its torqued to 220lbs 250 in reverse should be ok...in theory. Truck IS in park. Watched a video where a home made tool with two pins and a hole in the center was used to bust it loose hence why I said no home made tool. And lastly as stated impact wrench at 120psi cant budge it so that's where i am with that. Thinking either more psi somehow, 120 is this compressors max, or some form of gorilla tactics.
  4. Jun 15, 2015 at 11:03 PM
    Fabio760
    01 prerunner
    Finally got it! good ol blow torch impact driver combo
    darkyota33 likes this.
