Crank pulley small wobble + motor knock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Jul 16, 2017.
  1. Jul 16, 2017 at 10:00 AM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I've been noticing this horrible sound coming from around the pulleys. It looks as though the crank pulley had a wobble..
    Also the knocking started after switching to synthetic 5w-30
    Is this amount of wobble ok?
    https://m.youtube.com/watch?v=v1yV-ENEvNM
  2. Jul 17, 2017 at 3:09 PM
    anthony250f
    Anthony
    San Diego, CA
  3. Jul 17, 2017 at 3:12 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Looks normal to me. I would change the belt and clean everything then see what you have.
    To me it does not look like you have any pulley's jumping around. Dirt can make a pulley look like it is moving when its not.
  4. Jul 17, 2017 at 3:18 PM
    anthony250f
    Anthony
    San Diego, CA
    I'm trying to chase down that bad bearing sound
    Also my motor is now knocking too slightly after changing to synthetic mobile 1 5w-30
  5. Jul 17, 2017 at 3:19 PM
    anthony250f
    Anthony
    San Diego, CA
  6. Jul 17, 2017 at 3:20 PM
    JJ Customs
    Jay
    NV
    If you take the belt off and roll each ones of those you will know if one is bad. The other thing you can do it see what one is running hotter than the others. If one is failing it will be warmer than those around it. DONT TRY THAT WITH IT RUNNING!
    Geodude2018model and scottalot like this.
  7. Jul 17, 2017 at 3:21 PM
    JJ Customs
    Jay
    NV
    Sounds like you might have an exhaust leak. They can make your swear you have a hard knock also.
  8. Jul 17, 2017 at 3:30 PM
    anthony250f
    Anthony
    San Diego, CA
    That's what I thought too. Also here one of the heat shields rattle on a cold start.
    I'm going to put in some rotella 15w40 and see if the knock goes away.
  9. Jul 17, 2017 at 3:30 PM
    anthony250f
    Anthony
    San Diego, CA
    It sounds like a exhaust leak and a knock lol
  10. Jul 17, 2017 at 4:02 PM
    JJ Customs
    Jay
    NV
    Well if it is a lower end knock I doubt anything that comes out of a bottle is going to help it. Since you have so many things going on it might be worth taking it to a shop and getting a quote on what all is exactly wrong so you are not throwing money at what could be a bad motor.
    anthony250f[OP] and 12TRDTacoma like this.
  11. Jul 17, 2017 at 4:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hard to diagnose it from a computer. If you can't figure it out take it to a shop and get a well informed opinion. Short of that we are taking shots in the dark with a very limited amount of information and points of view available to us.
    anthony250f[OP] and JJ Customs like this.
  12. Jul 17, 2017 at 4:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you ever replaced any of your idler pulleys? That is definitely a strange noise.
    anthony250f[OP] likes this.
  13. Jul 17, 2017 at 4:36 PM
    anthony250f
    Anthony
    San Diego, CA
    I replaced the silver looking one in the video. I thought it was that one because I did the water test and it went away.....I sprayed water on the crank pulley a few days ago and it went away and has yet to return
    The motor did not knock what so ever before I put synthetic oil in.
    The video is the worst it has ever sounded, today it was noticeable but not as extreme.
    Motor has 190k
  14. Jul 17, 2017 at 4:38 PM
    anthony250f
    Anthony
    San Diego, CA
    Yeah good idea. It sounds like it's coming from right at the header area
  15. Jul 17, 2017 at 6:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'm with the other people who are thinking exhaust leaks. I heard injectors in the second video. With something that sounded like and exhaust related pulse or tick.
    Justinlhc likes this.
  16. Jul 17, 2017 at 7:00 PM
    anthony250f
    Anthony
    San Diego, CA
    Here's a video from the top
    https://m.youtube.com/watch?v=bdXxbxl163M
    When I look at the wobble it does not wobble at the side closest to the motor. It only looks like it's wobbling if I look at the front. The belt does not seem to move either.
    Either way I was gonna change the oil to rotella 15w-40
  17. Jul 17, 2017 at 8:03 PM
    anthony250f
    Anthony
    San Diego, CA
    The bearing sound came back this evening so I got out the spray bottle. I'm 80% sure it's idler 2 next to the ps pump. As I sprayed it would stop for a second then come back until about 10 sprays then it went silent.
    When the noise comes back and I have the time I will remove the belt and check the pulley
  18. Jul 17, 2017 at 8:06 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Get yourself a "mechanic's stethescope" : Use mine all the time, at 4$ its a no brainer to keep one in the garage. REALLY helps narrow down sounds like these.
  19. Jul 17, 2017 at 8:09 PM
    anthony250f
    Anthony
    San Diego, CA
    Sweet I will go grab one of those!
    excorcist[QUOTED] likes this.
  20. Jul 17, 2017 at 8:17 PM
    excorcist
    Reno, NV
    If its one of those pulleys, it will let you know... Also if you have a length of vacuum hose (or similar ID hose) you can use that in a similar manner, might be better for hearing an exhaust leak. Stick one end in your ear and the other around the area the noise is coming from.
    (I know the hose thing sounds weird but I was amazed at how well it works when I first tried it and have been doing it ever since in conjunction with the stethoscope)
    Torspd likes this.
