Crank pulley small wobble + motor knock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Jul 16, 2017.
  1. Jul 23, 2017 at 3:10 PM
    #41
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If the three pulley bearings were bad, the tensioner pulley bearing is not far behind. The bearing is easily replaceable; the size is 17X40X17.5 (ID X OD X Width). I replaced mine with a Nachi 5203-2NS bearing. Stick with Japanese, German, or Swiss brand.
  2. Jul 23, 2017 at 3:13 PM
    #42
    Chuy
    Lakeside, CA
    Silver Taco
    I just realized we replied to each other on this issue on another post ... hope you got it all sorted out.
    anthony250f[OP] likes this.
  3. Jul 23, 2017 at 3:32 PM
    #43
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I ordered the tensioner bearing!! Thanks for the part number! Exact one I got
    Tensioner bearing was shot too lol
  4. Jul 23, 2017 at 3:33 PM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Go through a lot of muddy water crossings, or just the age?
  5. Jul 23, 2017 at 4:20 PM
    #45
    anthony250f
    Anthony
    San Diego, CA
    I have not at all but it was clear that the previous owner did lol
    I bought it at 180k and I'm not at 190
    Pretty much replaced everything so far lol
  6. Jul 23, 2017 at 5:08 PM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A few more items and it will be running really well.
    Fuel filter next. ;)
  7. Jul 23, 2017 at 5:21 PM
    #47
    anthony250f
    Anthony
    San Diego, CA
    Oh god haven't even thought about that! Still need to do atf fluid, ps fluid, and t case oil
  8. Jul 23, 2017 at 7:33 PM
    #48
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Be careful with rotella.... There is Rotella T, rotella T4 ... both 15w-40.... Rotella T is a diesel oil, (as is Rotella T6) Both of which work GREAT in motorcycles (they are both jaso ma / ma2 certified) and because of that they have NO energy conserving additives (makes friction pieces very slippery, no bueno for wet clutches in motos) , which a gas vehicle motor should have.
    On shell's site the ONLY rotella product they claim to be ok to use in gas vehicles is their T6 "Multi Vehicle" which i can almost guarantee has the energy conserving additives vs the regular T6.
    That stated.... NONE OF THE ROTELLA T oil products meet the requirements of our motor. Yes, you read that right. NONE meet the ILSAC GF-5 grade.
    Needless to say, rotella oil does NOT belong in our truck, let alone any Xw-40w oil (unless you are high speed WOT constant desert running -very hot ambient temps- where oil temps are higher, which only a select few do)
    Dont get me wrong, i LOVE rotella T and T6 oils i use them EXCLUSIVELY in my wet clutch motorcycles.... but in our trucks NOPE, mobile 1 full syn 0w-30 only.
  9. Jul 23, 2017 at 7:38 PM
    #49
    anthony250f
    Anthony
    San Diego, CA
    I used the rotella t4 which was reccomended by @Speed Freek and a few others who swear by it.
    I'll have to look on the bottle to see what it says.
    I know the Subaru guys only run rotella
  10. Jul 23, 2017 at 8:36 PM
    #50
    nd4spdbh
    SoCal
    Im not saying that it wont work. Its great oil. But its likely not meeting the specs set out by toyota for our motors, and when the oil is the same price as a standard car oil, why risk it?
  11. Jul 23, 2017 at 8:49 PM
    #51
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Any particular reason you're using 15w oil? Comes from the factory with 5w20 IIRC (I think that's what I throw in mine). Read somewhere that the heavier weights can't be that good for the engine since its a different viscosity
  12. Jul 23, 2017 at 9:00 PM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Age, likely. The older Tacomas have a bit more robust set of bearings too. Which might mean slightly larger clearances. Might .
    You Volcom, should have an oil temp gauge. Running a 20 weight with an S/C, in hot climates is a sure fire way to over heat the oil. Especially if you don't have an oil cooler. A 20 weight is decent for cruising around, but definitely not for beating on. Doesn't have the resiliency to withstand heat as well as a 30 weight. It will get to 300ºF much easier. My recommendation is at a 30 weight. At least in the summer. With some added ZDDP.
  13. Jul 23, 2017 at 9:05 PM
    #53
    VolcomTacoma
    Jeff
    NorCal
    Will do. Was gonna do an oil change this week in fact. I'll switch it up to 5w30.
  14. Jul 23, 2017 at 9:08 PM
    #54
    VolcomTacoma
    Jeff
    NorCal
    I believe my Ultragauge has Oil temp on it, I'll throw that on my main screen to watch that closer.
  15. Jul 23, 2017 at 9:14 PM
    #55
    anthony250f
    Anthony
    San Diego, CA
    Switched to heavier oil due to high miles (190k) and it was reccomended. Truck runs MUCH better.
    Not sure what caused the knock to go away...the plugs or the oil but I'm glad it's gone lol
    Next oil change will likely switch back to normal oil...maybe 10w-30 or something
    Speed Freek likes this.
  16. Jul 23, 2017 at 9:40 PM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'd be good with a 5w-40 Anthony. Good protection and broader range of temperature flow characteristics.
    Speed Freek and anthony250f[OP] like this.
  17. Jul 23, 2017 at 10:09 PM
    #57
    anthony250f
    Anthony
    San Diego, CA
    I will try that next go around. I live inland San Diego and it's been 80-100 degrees every day
  18. Jul 24, 2017 at 12:05 AM
    #58
    Chuy
    Lakeside, CA
    Silver Taco
    Yeah, 15-40 sounds awfully heavy, even for SoCal weather. You said you're now running synthetic 5w-30, yes? If your engine is not knocking or burning oil, stay with that weight; it's what Toyota recommends for the Tacoma. Gas mileage will definitely go south with thicker oil.
    BTW, I'm a little east of you, in Lakeside. If you need help with something, don't be afraid to ask.
  19. Jul 24, 2017 at 1:09 AM
    #59
    anthony250f
    Anthony
    San Diego, CA
    I switched from 5w-30 to 15w40. Yeah probably overkill. I am going to run it for 5k and go back to a normal oil and hopefully with no knock lol
    Oh nice dude that's pretty close !
  20. Jul 24, 2017 at 5:27 AM
    #60
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If your rods were knocking, this whole conversation would be different. And you'd hear them still and feel a power loss.
