Crank pulley
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bdot, Feb 28, 2023.
  1. Feb 28, 2023 at 12:35 PM
    Bdot
    Bdot [OP] Member
    Brian
    2007 tacoma TRD v6
    Stock
    Is the crank pulley reverse threaded? I’ve tried a 750 lb impact
  2. Feb 28, 2023 at 12:39 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    righty tighty
  3. Feb 28, 2023 at 12:46 PM
    Bishop84
    Bishop84 Well-Known Member
    No it’s just f’n tight
    TnShooter, joeyv141 and HondaGM like this.
  4. Feb 28, 2023 at 12:48 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    lol yep. I was able to get mine off with a very powerful impact. You may need to bump start it to get it to move. over 200lbs of torque holding that sucker on.
    HondaGM likes this.
  5. Feb 28, 2023 at 12:50 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    You'r gonna need a big ass impact, I've got the M18 high torque and it can take them off but its really big to be shoving down in a tacoma engine bay unless you've already removed stuff.
    HondaGM likes this.
  6. Feb 28, 2023 at 12:52 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Geeves77 and ToyoTaco25 like this.
  7. Feb 28, 2023 at 12:52 PM
    nudavinci64
    Robert
    pretty sure that's exactly what I used. Then I used a stubby to put it back on.
    HondaGM likes this.
  8. Feb 28, 2023 at 1:04 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    100% accurate. my nephew has a 4cyl tacoma pulled his RAD and plugged the coolant lines to save as much as possible. but got a stubby impact up in that space and good to go!
    HondaGM likes this.
  9. Feb 28, 2023 at 3:39 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    Just bump start it using a breaker bar. My impact couldn’t remove mine either.
    burrito782 likes this.
  10. Feb 28, 2023 at 3:43 PM
    zguy1
    Midwest
    3JOH22A and burrito782 like this.
  11. Feb 28, 2023 at 3:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Pull the EFI fuse
    Bump starter
    You’re on your own for getting it back on tight.
    If you have manual trans, put it in gear and crank it down.
    If you have an auto, you either trust your impact, or buy the special crank pulley holder tool.
    Sketch factor :7.5 - Do this at your own risk:eek:
  12. Feb 28, 2023 at 4:09 PM
    zguy1
    Midwest
    Sketch factor is high for sure. It really did and does work. Make sure it’s on the bolt securely and braced up against the frame.
    Pull the fuse as mentioned.
    As soon as you turn the key, be ready to turn it back. Not because it will start, but because it will keep trying to turn the engine over. Hope that makes sense.
    You can use a pulley holderwhen trying to reinstall and torque the crank bolt. That’s what I did.
    Btw, I had one of these tools when I tried to take it off initially. However, I could not thread the two screws into the crank pulley that are required to install the pulley holder. That’s because the bolt holes were filled with crud and rust.
    You can use a tap or a thread restorer to clean up the threads before you put the pulley back on. The threads are M8 x 1.25.
  13. Mar 1, 2023 at 12:42 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
  14. Mar 1, 2023 at 12:56 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
