Crank pully
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacodown, Nov 7, 2016.
  1. Nov 7, 2016 at 4:32 AM
    tacodown
    tacodown [OP] Well-Known Member
    brant
    holtwood, Pa
    96 tacoma 2.7
    So looked under my hood while the truck was running and the inner pully closest to the block is noticely wobbling pretty good. Thinking that's a ticking time bomb has anybody used lc engineering underdrive pully or should I just replace with an oem. Posted a video on YouTube but it doesn't really do justice. Planning on doing the front main seal as well if I tear into this.
    LINK:
    https://youtu.be/h2Yyrzm8duY
  2. Nov 7, 2016 at 4:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'd just go with OEM
  3. Nov 7, 2016 at 11:54 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    OEM and tighten your stock one down first. It's probably fine. It probably didn't get torqued down properly when the timing belt was last replaced. 217lb/ft iirc
  4. Dec 23, 2016 at 6:42 PM
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
    The rubber is definitely separating from the metal. I have everything apart now and I've tried everything to my knowledge getting this bolt loosened and it Just won't budge. I'm not stopping until I either get it over or have to put it back together but I really don't want to do that cause tonight will be a big waste of time. Anybody with some tips or anything please give me a text haha 7174350054
    chaosrob likes this.
  5. Dec 23, 2016 at 6:50 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    I use a large chain wrench on the smooth part of the pulley,it will ends up resting against the frame rail. Then breaker bar with a cheater pipe in the bolt. After you get the bolt out wd40 on the pulley where it meets the crank and let it sit for 30 min, usually slide right of after. Good luck
  6. Dec 23, 2016 at 7:02 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Subbed.
  7. Dec 23, 2016 at 7:19 PM
    ChrisTRD1
    ChrisTRD1 Member
    Oregon
    99 4x4 SR5 TRD
    Bilstein 5100s OME 551 Alcan 5-leaf
    The easiest way to loosen the bolt is wedge a breaker bar against the frame rail and bump the starter for half a second (remove the EFI fuse so it cant start). The harder part is tightening it back to spec. I have a stick so I was able to put it into 5th and reef on it. If you have an auto, you will have to prevent the engine from turning with a chain wrench as mentioned earlier or something similar.
  8. Dec 24, 2016 at 4:47 AM
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
    Once I was able to get another person to sit in the cab and hold the brakes was able to break it with this beast. What a bolt ahaha and what a difference this new pulley makes for the old worn out one. The highest torque wrench I have goes to 150 ft lbs so I guesstimated from there
  9. Dec 24, 2016 at 9:57 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    Fwiw auto parts stores usually lend out 250lb torque wrenches as part of their free loaner programs. It's what I used when I did my TB.
  10. Dec 26, 2016 at 12:49 AM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    I have an LCE on my 2rz plus electric fan. 100% worth it, especially if you have to replace anyway. Been running mine at least 5 years now.
    I used the "Wedge a breaker against frame and hit the starter" method after not being successful with impact and such. Worked almost immediately.
