Crank the nose start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jake8822, Dec 9, 2023.
  1. Dec 9, 2023 at 12:28 PM
    Jake8822
    Jake8822 [OP] Member
    Jake
    Hello everyone. I'm looking for some help. I've got a 1996 toyota tacoma 2.4 l. My truck lost power and now it will not turn over. I had recently replaced the Transmission I don't know if that isn't anything to do with it. I have gotten through all fuses and replace the alternator but I got a distributor from a different year toyota. I changed the spark plugs spark plug wires. I did disconnect the after market alarm system. Does anybody have any idea what it could be?
  2. Dec 9, 2023 at 3:47 PM
    Pyts
    Pyts Well-Known Member
    09 2.7 RWD
    Stock
    Wrong sub forum, but check that you got the new coil wires installed in the correct order.
    :playball:
  3. Dec 9, 2023 at 3:56 PM
    Jake8822
    Jake
    Thank you very much for your reply. I've only posted on here one time but what is the correct order that goes on? Do you have a schematic of it?
  4. Dec 9, 2023 at 4:07 PM
    Waasheem
    Waasheem
    2007 xrunner
    96 would be a 1st gen.
    Be certain to describe your issues in detail and correctly. Perhaps it’s a language barrier issue but, crank the nose start makes no sense. When you turn the key, does it crank but fails to start?
    It’s also good to mention recent repairs, like the engine started and ran fine prior to replacing the transmission.
    Best of luck.
  5. Dec 9, 2023 at 4:41 PM
    Jake8822
    Jake
    Yes sir it cranks but doesn't turn over. Ok I will definitely make it more specific.
  6. Dec 9, 2023 at 4:48 PM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Aftermarket alarm items getting disconnected have caused a lot of issues for people. I’d try reconnecting and see what happens.
    @chris4x4 @ColoradoTJ
    Maybe mods can move it to correct sub forum please?
  7. Dec 9, 2023 at 4:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Does the horn work?
    ColoradoTJ likes this.
  8. Dec 9, 2023 at 4:52 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Moved. Thank you
    MarX likes this.
  9. Dec 9, 2023 at 4:54 PM
    Pyts
    09 2.7 RWD
    Stock
    I don't have a schematic for the spark plug wires, but.. The cylinders for the 4 cylinder engine are 1,2,3,4, starting with 1 at the front by the bumper, 4 by the firewall/windshield. So if your distributor has numbers to match, that should help.
  10. Dec 9, 2023 at 4:54 PM
    MarX
    Mark
    NE Kansas
    Thank you !
    ColoradoTJ[QUOTED] likes this.
  11. Dec 9, 2023 at 4:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do we have spark?
    Fuel?
    Do you have a can of carb cleaner?
    A plug wrench?
    We need to start somewhere.
    We need to know what we do and don’t have.
    MarX and ColoradoTJ like this.
  12. Dec 10, 2023 at 1:10 AM
    Jake8822
    Jake
    I have every tool known to man. I'm just not a mechanic I just like tools. Yes the horn does work and I have the spark plugs in the correct locations. Couldn't by chance be the clutch switch
    Pyts likes this.
  13. Dec 10, 2023 at 3:29 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Swap the horn and efi relay
  14. Dec 10, 2023 at 3:32 AM
    Jake8822
    Jake
    OK I'll try and do that. Thank you all for your help. I'll post updates.
    MarX and Steves104x4 like this.
