cranking the truck without oil?
Discussion in 'Technical Chat' started by 08pretaco, Jan 24, 2010.
  1. Jan 24, 2010 at 2:14 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    alright so i was talking to my dad the other day when i was changing my oil. we got to talking about weights and whatever else, he used to do like 10w-40 on his old thing and was amazed with the weights recommended now days.
    got under the truck pulled the drain plug and let it drain blah blah then started putting oil in. my dads was like: "you didnt crank it for a few seconds after you drained the oil?" i was like WTF? then he explain, not very well, what it did and all i got out of him was that he said after doing that, he got a lot of "gunky shit" out (supposedly).
    keep in mind that the car he did this on could probably run on hopes and dreams without anything in it. so my question is: is that good for your engine to do something like that?
  2. Jan 24, 2010 at 2:15 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    NNNOOOOOO!!!!!!!! Don't do this!!!!!!!!!
    You can cause engine damage, and or cause the engine to jam up.
  3. Jan 24, 2010 at 2:16 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    i wouldnt touch the key with no oil in my truck. Ive already had a couple engines from old vehicles go to crap because the oil level was down.
    Not sure it would help anything. I think it would do more harm then good
  4. Jan 24, 2010 at 2:16 PM
    Brunes
    Brunes abides.
    Rotorhead
    If you have been using good oil and doing regular changes- Not something I would mess about with personally....but ::shrug::
  5. Jan 24, 2010 at 2:17 PM
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    Never heard that nor would I ever try it.
  6. Jan 24, 2010 at 2:18 PM
    08pretaco
    Oliver
    az
    theres no way in hell i would ever do that, i was just curious if anyones ever heard of this lol my dads what 60 or so, meaning that his memory sucks and he is a very good story teller haha
  7. Jan 24, 2010 at 2:23 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Yes have heard of it, and it has been talked about on here too. I have seen some people do this, and get the engine stuck, and it would not turn over.
    I'm not sure if this is something they did a lot back in the day, but it would be crazy to do it now. lol
    I'm glad you didn't do it.
  8. Jan 24, 2010 at 2:25 PM
    08pretaco
    Oliver
    az
    iv learned, after almost 21 years, that somethings you listen to your dad about...things like this with modern vehicles and such, no way!
    if i did listen to him though, it would have been his fault and i would be getting that 5.7 iforce alot quicker :p
  9. Jan 24, 2010 at 3:19 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I heard you are supposed to drive on your bare rims for a few miles before you mount new tires too. Makes the bead seat better. :laugh:
  10. Jan 24, 2010 at 3:25 PM
    08pretaco
    Oliver
    az
    ^difference is someones has heard of what i was asking about
  11. Jan 24, 2010 at 3:31 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    This.
  12. Jan 24, 2010 at 3:42 PM
    KPT
    09 Prerunner
    Another difference is that what your talking about is much more damaging to the truck than what I said.
  13. Jan 24, 2010 at 3:46 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    On a regular oil change, you're getting the majority of the crap out with the old oil anyways. If you crank it, I can see some components getting shredded, causing more crap to float around in the crankcase.
    If you really want to clean out the crankcase, use flushing oils. But this is not usually necessary if you've been changing your oil regularly and not using dirt as a lubricant and such.
    Great guide for everything oil:
    http://www.carbibles.com/engineoil_bible.html
  14. Jan 24, 2010 at 5:36 PM
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    Never cranked an engine without oil in the pan.
    I did however use to drive on new tire about 500 miles before balancing them. A lot of time the ru-glyde will cause the tires to actually moves on the rims. Uses tire crayon to prove this. The Old BF Goodrich Radial T/A were so out od round used a dial indicator to measure the run out of the rim and move the high side of the BFG tire to the low point on the rim. Also used to send BFG's to a local tire shop to have them trued before balancing.
  15. Jan 26, 2010 at 6:52 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Hey, hey, Dad said to pull the coil wire before you turned it over, Right
  16. Jan 28, 2010 at 11:30 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Get this: my motorcycle manual says to kick the engine over a few times after draining the oil "to get the remaining used oil out of the oil pump" or something to that effect. Some people have done this and resulted in an oil pump that was no longer primed and not pumping oil after the engine started. (Fortunately the engine made some noise before it blew up, so they shut it down and were able to prime the oil pump before restarting.) Personally, I have never been comfortable kicking or cranking any engine unless the case is full of oil. I say don't do it.
  17. Jan 31, 2010 at 3:59 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    You'd be amazed at how long an engine will run with no oil in it. Usually more than a few minutes.
    There's a lot of oil left in the engine after you drain it. Enough that a couple cranks won't hurt anything. However, I would highly suggest not allowing it to start, that will cause damage almost immediately. I'd also say there is no benefit to cranking it over. You'd be better off to just let it drip for an hour or two.
  18. Jan 31, 2010 at 4:13 PM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    A long time ago I was at this hillbilly town spring fest- thing, and the evenings main entertainment was a lynard skynard cover band followed by the event organizers running a ford fairmont station wagon with no oil. They sold people raffle tickets on how long it would run. It actually went almost 5 minutes before it stalled....I lost 5 bucks.
  19. Jan 31, 2010 at 4:58 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Don't forget to clean the cylinders with water after you've drained all the oil. Then run it to get everything out.
  20. Feb 1, 2010 at 9:56 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    You tube is full of cash4clunker engine kills. One fellow who worked at a dealer reported the range of 20 seconds to 20 min. iirc. Not sure how long this ran before the video starts but it's almost 10 min to kill with liquid glass instead of oil....
    http://www.youtube.com/watch?v=0K8Zi2aoLlI&NR=1
    Back to burping the oil out--we used to do it, but it's not needed unless you've got some 25000 mile oil in there. Otherwise, just put in two clean quarts, run it 10 seconds and drain again if you must get out as much old oil as you can.....
