Cranks but doesn't Start! Help, tried almost everything.
Discussion in 'Technical Chat' started by Euston, May 20, 2012.
  1. May 20, 2012 at 7:59 PM
    Euston
    Euston [OP] Member
    New Jersey
    2000 Tacoma 3.4L 4x4 manual Supercharged
    Supercharger, small lift
    2000 tacoma 3.4l 4x4 manual supercharged. Long story short, Friends truck not mine just trying to help him. Truck went through a lot of deep mud, drove it home but died due to alternator stopped charging. Tried to jump it and it wouldn't run. It smells like the truck is dumping a ton of fuel and the spark isn't strong enough to ignite it. Checked fuel pressure and it's ok @ 45psi. I have spark and injector pulse. I replaced the computer, igniter, spark plugs, crank sensor. I have no codes. This truck is driving me crazy!
  2. May 21, 2012 at 5:12 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Did you try to clean throttle body ? In case something is not right there.
  3. May 21, 2012 at 5:20 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Did you get all the mud out of the alternator? And battery.... If alternator is clogged, then it's not charging the battery so the battery probably died. Have you tried a push start? Will stay on when you push start it?
  4. May 21, 2012 at 1:00 PM
    Euston
    Euston [OP] Member
    New Jersey
    I forgot to mention that I replaced the alternator and cleaned the throttle body. I didn't try push starting it cause it cranks but doesn't start. I guess I could give it a try....
  5. May 21, 2012 at 1:01 PM
    Euston
    Euston [OP] Member
    New Jersey
    Is it true that this truck will start if the cam sensor is bad or disconnected? I don't have a way to check it, that's why I asked.
  6. May 21, 2012 at 5:16 PM
    Euston
    Euston [OP] Member
    New Jersey
  7. May 21, 2012 at 5:20 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    give it some gas.....sorry i know not helpful.
    BUMP
  8. May 21, 2012 at 5:27 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    this....
    I'd diagnose the cam and crank sensor. you'll get spark if a cam sensor is bad but won't fire .02
  9. May 21, 2012 at 6:02 PM
    babytruck
    NorCal
    Did you try to push start it yet?
  10. May 21, 2012 at 6:11 PM
    Manwithoutaplan
    ID
    was gooing to ask that :D
  11. May 21, 2012 at 7:01 PM
    Euston
    Euston [OP] Member
    New Jersey
    No I couldn't push start is today cause it's pouring here in Jersey. I've read that the truck will run if the cam sensor is disconnected but I'm not 100% if that info is true. I replaced the crank sensor and nothing. I did have a scanner for a few days and the scanner sees cranking rpm. I have strong spark. While cranking the truck over I do smell a lot of fuel as if it's flooded. I checked fuel pressure and it's 45psi, which is within specifications. I have injector pulse. What I'm not sure about is when I have someone crank the truck over, there is very little suction through the intake. The air flow is about neutral. Now don't forget that this truck is supercharged and I don't know if that is normal. Also when I removed the pcv valve and had someone crank the vehicle, I can feel air blowing and sucking from the hole in the valve cover, which I think means the piston rings are worn out. I did a compression check and it was a little under spec but ok. I only did it on one cylinder, I should've did it on all so I will check them tomorrow.
  12. May 22, 2012 at 3:30 AM
    nj636
    Kev
    Jersey
    where in jersey are you?
  13. May 22, 2012 at 11:21 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Was there any water in the intake? Is the exhaust plugged with mud?
  14. May 22, 2012 at 1:47 PM
    Euston
    Euston [OP] Member
    New Jersey
    I'm in Toms River. I removed the o2 sensor to see if the cat or muffler is clogged and it's not. He ingested a little bit of water but when he did we removed the air filter and he drove it until the battery was completely dead. For some reason I think it may be the cam sensor but can anyone tell me if it will run if it's bad.
  15. May 22, 2012 at 3:03 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Check the cam sensor. There should be a reference voltage lead, a signal lead, and ground, iirc. The signal should fluctuate while cranking. DO NOT USE A TEST LIGHT. You need a high impedance multimeter.
  16. May 23, 2012 at 4:04 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) I am Sorry about your problem. You need 3 things to get your engine to run: fuel, air and a spark at the correct time. You may have a slipped or bad timing belt. How many miles do you have on your Taco ? You mentioning that there is very little suction on your intake is a clue that something is out of time. I know the supercharger being on the front makes it tough to get to everything, but you may need to open it up to check the timing belt. Good Luck.
  17. May 23, 2012 at 7:57 PM
    Euston
    Euston [OP] Member
    New Jersey
    ****UPDATE***** You hit the nail on the head with that one. The Timing was waaay off. The timing belt was stretched and I guess dry mud got into the wrong place at the wrong time and she skipped a lot of teeth. After I fix the timing issue she fired right up. The lack of intake suction was a huge clue that I kinda brushed off. Thanks to everyone who tried to help!!!
  18. May 23, 2012 at 8:05 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Nice diagnostic and repair work!
  19. May 24, 2012 at 5:33 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Ahhh... Timing belt. I do not miss you!
  20. May 24, 2012 at 7:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Change the oil if you haven't already. If you slipped a tooth on the timing belt, that makes me think of water in the cylinders.....and of course in the oil as well.
