Cranks, but no start 08 Tacoma 2.7L 5 lug base model
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hodges87, Aug 17, 2021.
  1. Aug 17, 2021 at 8:46 AM
    Hodges87
    Hodges87 [OP] Active Member
    JR
    Texas
    08 Tacoma
    Hello
    I'm helping a friend with his Tacoma, and I need some help. Here is the story I was told. The truck wouldn't start, so he had the fuel pump replaced. It still wouldn't start. The mechanic gave up on it and told him he could not fix it.
    No CEL, and my scan tool can't connect to ECM
    This is what I have done so far:
    Charged Battery just to be sure
    Checked all fuses in both locations and tested for voltage
    Checked and swapped relays around
    Pulled fuel tank and checked connections
    I tried spraying starting fluid to test for ignition (Didn't start or even try to start)
    It's the 5 lug base model, so I don't think it has the immobilizer (The light never comes on and he was using an aftermarket key with no chip (I even got the original key and tried that)
    New plug & play ECM, (scan tool still can't connect)
    Jumped the OBD pins for 30mins to reset everything (per youtube videos)
    New OE Denso Crankshaft sensor
    I'm completely stumped!
    I've searched and read a lot of posts on here, but haven't found a solution.
    Thanks,
    JR
  2. Aug 17, 2021 at 10:29 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have no CEL with the key on and can't communicate with the PCM you could have:
    A power or ground feed problem at the PCM.
    A problem with the CAN network (unlikely to cause a no start and no CEL).
    A shorted 5v Ref circuit.
    A wiring problem.
    A bad PCM.
    I'd start with checking all powers and grounds at the PCM with a test light just be careful that you don't spread the pins in the connectors.
    TnShooter likes this.
  3. Aug 17, 2021 at 11:08 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    Thank you Sir! I will start checking everything out
  4. Aug 17, 2021 at 2:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did it start with starting fluid or not?
    I assume it did not.
    I too would begin by checking power to the ECM.
    The US 2.7 liter Tacoma's do not have an Immobilizer System and doesn't have or need a chipped key.
  5. Aug 18, 2021 at 3:34 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    No, it did not start
  6. Aug 18, 2021 at 3:51 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    So was the truck running fine then one day would not start?
    rtilton12 likes this.
  7. Aug 18, 2021 at 6:44 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Check pin 16 on the OBD port for voltage as well as all the ECU voltages and grounds.
    What OBD scanner are you using? Something like a scan gauge or a wireless and using an app? If it is a wireless does it light up when you turn the key on as mine does?
  8. Aug 20, 2021 at 9:56 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    Yes
  9. Aug 20, 2021 at 9:59 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Have you checked for spark?
    TacooSaucee likes this.
  10. Aug 20, 2021 at 10:08 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    Pin 16 has 12v, OBD Link MX+, it lights up
  11. Aug 20, 2021 at 10:11 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you gotten around to checking powers and grounds at the PCM yet?
  12. Aug 20, 2021 at 10:12 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    As mentioned, check your spark and electical.
    Also what happened when you sprayed fuel? any stutter? I'm getting at the fuel filter/fuel line may be clogged but seems unlikely.
  13. Aug 20, 2021 at 10:12 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    I'm about to start on that right now
  14. Aug 20, 2021 at 10:14 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Check your fuel pressure and with nothing to lose, pull the starter and battery and go have both loaded tested.
  15. Aug 20, 2021 at 11:00 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    The pins with the red circles have 12v with the key on. Pin 3 (brown wire) does not have any power with key on or off. Is pin 3 supposed to be 12 battery (always on) according to the ECM pinout?
  16. Aug 20, 2021 at 11:16 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Brown wire looks like it should be a ground according to the wiring diagram.
  17. Aug 20, 2021 at 11:30 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    I'm having trouble understanding Question.jpg Connecter E4 Pin 3.jpg what connector pins to look for. In the red circled area, I would look for Connector E4 pin 3. Is that correct?
  18. Aug 20, 2021 at 11:36 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea, Mitchel must have something screwy with their pinouts because I looked on both wiring diagrams (06 OE and 08 Mitchel redrawn) and connector e4 pin3 brown goes to a ground at the rear of the cylinder head.
  19. Aug 20, 2021 at 11:39 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I have the 06 FSM on my PC at home I'll have to see what the pinouts show on there when I get home.
  20. Aug 20, 2021 at 11:46 AM
    Hodges87
    JR
    Texas
    08 Tacoma
    Thanks, I appreciate it
