Cranks, but no start 08 Tacoma 2.7L 5 lug base model
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hodges87, Aug 17, 2021.
  1. Aug 20, 2021 at 12:11 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    That's what the schematic seems to show as well.
  2. Aug 20, 2021 at 1:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree everything I have says that brown wire is a ground. Should be easy to check with a quick continuity check with the truck off check that terminal to a good chassis ground. Should read 0 ohms resistance.
    All of the Brown Wires go to ground and are used for shielded connections where the white with a black stripe are regular signal / power return ground wires.
  3. Aug 20, 2021 at 2:02 PM
    Hodges87
    Hodges87 [OP] Active Member
    JR
    Texas
    08 Tacoma
    It does read 0 ohms resistance. Do you know what terminals I need to test for 12v ign and 12v consistent power to ecm?
    Jimmyh[QUOTED] likes this.
  4. Aug 20, 2021 at 2:20 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Connector E8 pin1 black, pin 3 blue, pin 7 light green pin 9 orange
    Jimmyh likes this.
  5. Aug 20, 2021 at 2:23 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    pin 22 and 29 (White/Black) on E8 should be grounds
    Jimmyh likes this.
  6. Aug 20, 2021 at 2:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    12v Ignition Power - Orange Wire from the IGN Fuse, Terminal # 9.
    12v Consistent - Blue Wire is Battery from the EFI Fuse, Terminal # 3.
  7. Aug 20, 2021 at 2:38 PM
    Hodges87
    JR
    Texas
    08 Tacoma
    Connector E8
    Pin 1 (black) no power
    Pin 3 12v
    Pin 7 12v
    Pin 9 12v with key on
  8. Aug 20, 2021 at 2:42 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    see if you have power on the EFI no2 fuse, if not check the EFI Relay.
    Jimmyh likes this.
  9. Aug 20, 2021 at 2:54 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Wouldn't pin # 1 Black come from the EFI Fuse through the EFI Relay then to Pin # 1?
    The EFI Relay supplies power to the EFI No2 Fuse...
    EFI Fuse >> EFI Relay Contact >> EFI No 2 Fuse, COPN Relay Contact and ECU Pin # 1 Via the black Wire.
  10. Aug 20, 2021 at 2:57 PM
    Hodges87
    JR
    Texas
    08 Tacoma
    EFI # 2 fuse 12v, the red circled areas have 12v on relay
  11. Aug 20, 2021 at 3:02 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The other side pin should be a ground and the bottom pin feeds the black wire.
  12. Aug 20, 2021 at 3:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Maybe i misread the diagram, I've been glancing through it when I've had free time at work.
  13. Aug 20, 2021 at 3:25 PM
    Hodges87
    JR
    Texas
    08 Tacoma
    I verified the relay does supply power to the bottom pin in the picture, with the key on
  14. Aug 20, 2021 at 3:29 PM
    Hodges87
    JR
    Texas
    08 Tacoma
    With the connector plugged into the ECM the E8 pin1 black has 12v with key on
    Jimmyh likes this.
  15. Aug 20, 2021 at 4:25 PM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    Then all of your power is correct on the ECM.
  16. Aug 20, 2021 at 4:28 PM
    #36
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    And you verified grounds on E4 pins 6 & 7 (White/Black) and E8 Pins 22 & 29 (White/Black)?
  17. Aug 20, 2021 at 4:30 PM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Also E5 Pins 3,4, & 7 (White/Black) should be grounds.
  18. Aug 20, 2021 at 5:00 PM
    #38
    tirediron
    Ensure you verify grounds with an incandescent test light, and NOT simply a DVOM.
    Hodges87[OP] and Dm93 like this.
  19. Aug 20, 2021 at 5:07 PM
    #39
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    For sure and/or see the link in my sig about using a DVOM.
    Hodges87[OP] likes this.
  20. Aug 20, 2021 at 6:46 PM
    #40
    Hodges87
    JR
    Texas
    08 Tacoma
    All grounds tested good. There was not a E8 pin 29. I'm using a Snap-on led test light that turns green when you find a ground
