Cranks, but no start 08 Tacoma 2.7L 5 lug base model
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hodges87, Aug 17, 2021.
  1. Aug 21, 2021 at 6:30 AM
    #61
    Hodges87
    Hodges87 [OP] Active Member
    JR
    Texas
    08 Tacoma
    I want to thank everyone again for helping me.
    I will look for a non led test light and test grounds again.
    I did find out some more back ground info from my friend.
    The truck sat at the mechanic's shop for months and during that time the battery went dead and was left dead for a very long time. The battery was replaced with a good used one. It tested good and I keep it on a float charger when I'm not working on it.
    I do have the old ECM
  2. Aug 21, 2021 at 1:50 PM
    #62
    Hodges87
    JR
    Texas
    08 Tacoma
    (e)Measure the resistance of the wire harness side
    connector.
    VC (E4-23) - Body ground Result 14.32 K Ohms
    VCPA (E8-26) - Body ground Meter didn't register anything
    VCP2 (E8-27) - Body ground Meter didn't register anything
  3. Aug 21, 2021 at 3:40 PM
    #63
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Is that just from the connector to battery negative? If so... there's your problem lady (or at least a problem)!
  4. Aug 21, 2021 at 5:40 PM
    #64
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    All 3 should be 10 kΩ or higher. VC/E4-23 looks like it passes.
    The other 2 do not.
    I’ll wait and see what @Dm93 has to say here.
  5. Aug 21, 2021 at 7:29 PM
    #65
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd stick it in and see if you still have 0V on the 5v Ref wires.
    Do you know what happened to the truck prior to it not starting? Did it die going down the road or did it just not start one day or what?
    Technically they all pass if your meter was reading OL Mohms on the other two although I am wondering where the 14 Kohms is coming from if everything is unplugged.
  6. Aug 21, 2021 at 10:34 PM
    #66
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok, @TnShooter has correctly identified an error in the pinout of the test (I actually accidentally posted the 5v Ref test for the v6 engine:facepalm:), VC is actually connector E4 Pin 18 Blue.
    That explains the 14 Kohms, you were actually testing the IGTF circuit not the VC circuit.
    Here is the correct one, I corrected it in my previous post as well.
    Jimmyh and TnShooter like this.
  7. Aug 27, 2021 at 5:19 AM
    #67
    Hodges87
    JR
    Texas
    08 Tacoma
    Thank you Sir! Will get everything tested today and report back.
  8. Aug 27, 2021 at 10:31 AM
    #68
    Hodges87
    JR
    Texas
    08 Tacoma
    Tested E4-18
    With connector unplugged multi meter shows OL
    With connector plugged in 6.8 ohms
    With connector plugged in and key on, 16 ohms
    I bought a Matco MD1668A circuit tester (old bulb style incandescent)
    Tested the following grounds
    E4 Pin 3, 6, 7 Good
    E5 3, 4, 7 Good
    E8 22 Good
    Tested for 5v with key on plugged into ECU
    E4 Pin 18 nothing
    E8 Pin 26 .6V
    E8 27 nothing
  9. Aug 27, 2021 at 10:45 AM
    #69
    Hodges87
    JR
    Texas
    08 Tacoma
  10. Aug 27, 2021 at 11:01 AM
    #70
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you try the old pcm and see if you still have no 5v?
  11. Aug 27, 2021 at 11:12 AM
    #71
    Hodges87
    JR
    Texas
    08 Tacoma
    Yes, the tests I just did was with old ECM
  12. Aug 27, 2021 at 2:07 PM
    #72
    Hodges87
    JR
    Texas
    08 Tacoma
    Anything else to try?
  13. Aug 27, 2021 at 5:40 PM
    #73
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Powers:
    E8 Pin 1 Black
    E8 Pin 3 Blue
    E8 Pin 7 Green
    E8 Pin 9 Orange
    Grounds:
    E4 Pin 3 Brown
    E4 Pin 6 White/Black
    E4 Pin 7 White/Black
    E5 Pin 3 White/Black
    E5 Pin 4 White/Black
    E5 Pin 7 White/Black
    E8 Pin 22 White/Black
    E8 Pin 29 White/Black
    5 V Ref:
    E4 Pin 18 Blue
    E8 Pin 26 Red
    E8 Pin 27 Blue
    I can't think of anything else that would cause a no com and no CEL if powers and grounds are good and the 5v ref wiring is not shorted you should have 5v on that wires and it should talk, everything points to a bad PCM (just very strange to have 2 bad ones).
    Just to verify the CEL works you can ground E7 Pin 30 Brown with your test light and see if it lights up, if you have access to depinning tools you could de-pin the 5v wires 1 at a time and see if you get your 5v back just to 100% verify no shorts.
    Will your scanner communicate with other modules on the vehicle?
  14. Aug 28, 2021 at 6:48 AM
    #74
    Hodges87
    JR
    Texas
    08 Tacoma
    Surprisingly, I'm able to communicate with ABS and Airbag system. I will get everything tested and report back.
    This is where I ordered the PCM from https://www.ebay.com/itm/124524691870?ssPageName=STRK:MEBIDX:IT
    I could order another PCM as a last resort. Where is the best place to order one from?
    #74
  15. Aug 28, 2021 at 8:40 AM
    #75
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That tells me the CAN network is functioning.
    Unless we're missing something I'm out of ideas, if a Toyota tech would like to chime in with any other suggestions that would be nice.
    If you have the ability to write the VIN and reset the immobilizer (not sure if there's any other setup required) I'd say grab a used one off hollander parts.
  16. Aug 28, 2021 at 3:14 PM
    #76
    Hodges87
    JR
    Texas
    08 Tacoma
    Powers:
    E8 Pin 1 Black No, I may have over looked this before
    E8 Pin 3 Blue Yes
    E8 Pin 7 Green Yes
    E8 Pin 9 Orange Yes
    Grounds:
    E4 Pin 3 Brown Good
    E4 Pin 6 White/Black Good
    E4 Pin 7 White/Black Good
    E5 Pin 3 White/Black Good
    E5 Pin 4 White/Black Good
    E5 Pin 7 White/Black Good
    E8 Pin 22 White/Black Good
    E8 Pin 29 White/Black No pin to test
    5 V Ref:
    E4 Pin 18 Blue Nothing
    E8 Pin 26 Red Nothing
    E8 Pin 27 Blue Nothing
    CEL does come on you can ground E7 Pin 30 Brown
  17. Aug 28, 2021 at 3:21 PM
    #77
    Hodges87
    JR
    Texas
    08 Tacoma
    I can get a power probe if need be. I have never used one on any testing. I think I may be on to something if I don't have power on E8 Pin 1 black. All fuses check out good.
  18. Aug 28, 2021 at 7:10 PM
    #78
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you test it with the PCM plugged in? That pin gets power from the EFI Relay which is controlled by the PCM by applying power to E8 Pin 8 Green/White
    TnShooter likes this.
  19. Aug 29, 2021 at 12:02 AM
    #79
    TnShooter
    Deogee
    STOCK
    That’s all I see as well.
    The E8-1 is the main power supply for the ECM. No need to go any further until we get power here.
    If the ECM was plugged in, it might be worth checking the power and grounds at the EFI Relay.
    Other than that, I’m out of suggestions.
    D2. likes this.
  20. Sep 5, 2021 at 8:58 AM
    #80
    Hodges87
    JR
    Texas
    08 Tacoma
    E8-1 Black wire, does have 12.5v with the key on plugged into the ecu. I tested it "unplugged" originally (made that mistake twice)
